garner
  • 8
Message 1 of 10
500 broadband speed is closer to 200
I recently upgraded from the 200 MB to the 500 MB package, and I'm seeing very little difference in download speeds. The 200 was always consistently above 200, while the new 500 gives me maybe a 10% improvement, if that.
I'm using the Hub 3 in modem mode, testing via a wired connection. The best I've seen so far is around the 270 MB mark, worst is around 200 MB, and it mostly hovers around 230-240, which is basically what I'd expect to see from my old package on a good day. I might as well get rid of it if I don't see any improvement soon. I'm paying for it, but how can I tell if the 500 MB upgrade has been activated?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: 500 broadband speed is closer to 200
Do you have any kind of router sat between the Hub and the testing PC ?
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
garner
  • 8
Message 3 of 10
I couldn't get it connected directly in modem mode, for some reason, but I rebooted and switched to router mode to connect directly. That gave me 532 MB. So it's something about the router (Netgear R8000) that's limiting things. Could be tricky to solve, but thanks for pointing me in the right direction!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 10
Try this to start with ...
Log into the R8000.
Advanced > WPS Wizard > QoS Setup > untick Enable Dynamic QoS
garner
  • 8
Message 5 of 10
Dynamic QoS is off, and the cable between the Hub and the router claims it's cat 5E. I tried swapping the cable for a different one but no luck there.
Anonymous
Not applicable
Message 6 of 10
On your speed tests it appears you are using wireless.
What speeds do you get if you connect wired to the Netgear?
garner
  • 8
Message 7 of 10
I'm definitely not using wireless. My computer doesn't have any wireless functionality - I know this because built it! 🙂
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 10
The symbology is certainly showing the results as Wi-Fi.
On the desktop app my results has a double ended arrow to denote ethernet.
On the internet it shows the Wi-Fi symbol - spooky.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 10
You know the speed to the Hub is over 500Mbs meaning the slow down is therefore caused by the R8000 or do one of the two ethernet cables or a combination of the two.
What speed do you get using a decent Wi-Fi device about 3 or 4 feet from the R8000 ?
garner
  • 8
Message 10 of 10
Thanks for your help! You definitely got me on the right track, and it was a factory reset of the R8000 that finally did the trick. It's now around 530-540 MB both wired and wireless.
I have no idea what setting it was that was throttling the speed, or why it was affecting everything on the network. I have an access point in another part of the house that I had previously assigned a static IP address to, there was a port being forwarded to this PC and a device in the DMZ. I shouldn't think those things would throttle all traffic through the router, but they're gone now.
I'm gradually restoring my settings and testing the speed after each one, so maybe I'll find out what it was.
Thanks again!
