  • 57
50% loss of speed suddenly, like its capped.
Normally here in southampton I do not have issues with my connection rates, on my 1gig connection and tested with ookla it has always been around 970 Mbps on the speed of connection and 52 upload which is fantastic. But of late and possibly in last 2 weeks I have seen that no matter where or when I connect for a test with say OOKLA speed test site I get a connection of 470 Mbps. This is almost 50% loss in speed from my contract. It has never ever been this bad down here.
Here are the channel downstream connection frequency and power db's
https://gyazo.com/4a23b1e062b67209a8c49f7b82657030
Here are the locked status's and Rx db connections and RS ererors.
https://gyazo.com/714859578b3b81685b9d0560dde5ef6e
I put them in as tables but the message would not post as it said no more than 20,000 characters per post.. so you have them as screenshots instead.
Here are some service flow info's as well
SFID
653482
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
653481
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
I restarted the router as well left it off for short time and turned on again. If the connection was a little iffy I would of thought I would of got random connection speeds but its always like its pushing to 470 Mbps Maximum.
Thanks for your time and hope to hear from you soon.
  • 20.96K
  • 1.13K
  • 2.7K
Re: 50% loss of speed suddenly, like its capped.
Wired? Wireless?
  • 57
Wired, I never touch wireless. As stated in my last post not had issues with connection or speeds with the 1gig and hub4. Its just not locking into the 1gig config it seems. Or there is something majorly at fault somewhere.
  • 20.96K
  • 1.13K
  • 2.7K
What speed do you get here: https://samknows.com/realspeed/
  • 57
Please check your SamKnows enabled device is turned on and connected to the internet.
^^ wth is that, what is wrong with ookla site? doesnt work, i hit refresh and it tries to test the speed u see the hub info and all that but then a page shows with that message.
Edit: ah it seems like some special site regarding router access. Anyhow does not work for virgins hubs i guess. Problem still stands in that case 😄
  • 20.96K
  • 1.13K
  • 2.7K
It tests the direct speed doing to the hub.
Are you running in modem mode with your own router attached?
