Plumber1066
  • 7
Message 1 of 20
50% down on speed - 50Mbs of M100 connection
Speed has been slow for over a week - approx only 50% of contracted M100
Tags (2)
Buffer6
  • 11.17K
  • 93
  • 631
Hero
Message 2 of 20
Re: 50% down on speed - 50Mbs of M100 connection
Are you testing wired or W-FI ?
Plumber1066
  • 7
Message 3 of 20
WIFI - normally get around 100 but last week or so has dropped to around 50.
will try a wired test tomorrow
Emma_C
  • 8.28K
  • 512
  • 559
Message 4 of 20
Hi Plumber1066,
Really sorry you're having some issues with the speeds lately and for the delay in getting back in touch, we have been busier than normal.
Are you still having these issues now?
I've had a look at the back end of things from here and can't see any issues, but the hub has been up for some time.
Do let us know how you're getting on.
Emma_C - Forum Team
Anonymous
Not applicable
Message 5 of 20
what speeds did you get on a wired speed test
Plumber1066
  • 7
Message 6 of 20
Still poor speeds - just teated wireless and download is 29.9 and upload 5.88.
have restarted hub a number of times over the last couple of weeks and has not helped.
Anonymous
Not applicable
Message 7 of 20
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
Plumber1066
  • 7
Message 8 of 20
Wired Speedtest is showing 80.51 and 10.06
Anonymous
Not applicable
Message 9 of 20
you need to test with a wired connection to know if its the connection or a wireless problem. Advice will change depending on that
Anonymous
Not applicable
Message 10 of 20
cool so its not a connection problem so hub stats are pointless.
You can try changing the wireless channel. as well as disabling smart wifi
