philpf
Message 1 of 1
5 Mbit upload speed on 1Gbit pack
Hello,
For the last year I have been consistently  getting slow upload speeds of 2-9 Mbit/s during working hours. I was on the M200 pack so have upgraded to 1Gbit in the hope I would get faster average speeds. However, I am still only getting 5 Mbit. A recent engineer visit got cancelled because apparently there was a fault in the area. The telephone support keeps saying "oh it will all run normal again after this is fixed" but the issue has been around for the last year. Upload speeds ar usually between 500 and 700 Mbits/s (1 Gbit in the early mornings).
The speed readings are taken using the built in SamKnows Real Speed SDK so are better than "wired".
Below are my details:
Cable Modem Status
Item Status Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview Downstream Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
hannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
5 170750000 3.500000 38.983261 QAM256 5
1 138750000 3.900002 38.605377 QAM256 1
2 146750000 4.099998 38.983261 QAM256 2
3 154750000 3.900002 38.983261 QAM256 3
4 162750000 3.599998 38.605377 QAM256 4
6 178750000 3.599998 38.983261 QAM256 6
7 186750000 3.799999 38.983261 QAM256 7
8 194750000 4.000000 38.983261 QAM256 8
9 202750000 4.199997 38.605377 QAM256 9
10 210750000 4.400002 38.605377 QAM256 10
11 218750000 4.599998 40.366287 QAM256 11
12 226750000 4.900002 38.983261 QAM256 12
13 234750000 5.000000 38.605377 QAM256 13
14 242750000 5.400002 40.366287 QAM256 14
15 250750000 5.300003 38.983261 QAM256 15
16 258750000 5.500000 38.605377 QAM256 16
17 266750000 5.300003 38.983261 QAM256 17
18 274750000 4.900002 38.983261 QAM256 18
19 282750000 4.800003 40.366287 QAM256 19
20 290750000 4.699997 40.366287 QAM256 20
21 298750000 4.900002 38.983261 QAM256 21
22 306750000 5.099998 40.366287 QAM256 22
23 314750000 5.199997 40.366287 QAM256 23
24 322750000 5.300003 38.983261 QAM256 24
25 330750000 5.400002 38.983261 QAM256 25
26 370750000 5.300003 40.366287 QAM256 26
27 378750000 5.300003 38.983261 QAM256 27
28 386750000 5.300003 40.366287 QAM256 28
29 394750000 5.300003 38.983261 QAM256 29
30 402750000 5.400002 40.366287 QAM256 30
31 410750000 5.500000 40.946209 QAM256 31
3.0 Downstream channels
5 Locked 38.983261 0 0
1 Locked 38.605377 0 0
2 Locked 38.983261 0 0
3 Locked 38.983261 0 0
4 Locked 38.605377 0 0
6 Locked 38.983261 0 0
7 Locked 38.983261 0 0
8 Locked 38.983261 0 0
9 Locked 38.605377 0 0
10 Locked 38.605377 0 0
11 Locked 40.366287 0 0
12 Locked 38.983261 0 0
13 Locked 38.605377 0 0
14 Locked 40.366287 0 0
15 Locked 38.983261 0 0
16 Locked 38.605377 0 0
17 Locked 38.983261 0 0
18 Locked 38.983261 0 0
19 Locked 40.366287 0 0
20 Locked 40.366287 0 0
21 Locked 38.983261 0 0
22 Locked 40.366287 0 0
23 Locked 40.366287 0 0
24 Locked 38.983261 0 0
25 Locked 38.983261 0 0
26 Locked 40.366287 0 0
27 Locked 38.983261 0 0
28 Locked 40.366287 0 0
29 Locked 38.983261 0 0
30 Locked 40.366287 0 0
31 Locked 40.946209 0 0
3.1 Downstream channels
33 86 4K 1680 QAM4096 424
33 Locked 42 5.6 343922969 0
3.0 Upstream channels
1 39400000 46.770599 5120 KSym/sec 64QAM 4
2 46200000 47.020599 5120 KSym/sec 64QAM 3
3 25800000 47.020599 5120 KSym/sec 64QAM 6
4 32600000 46.520599 5120 KSym/sec 64QAM 5
1 US_TYPE_STDMA 0 0 0 0
2 US_TYPE_STDMA 0 0 0 0
3 US_TYPE_STDMA 0 0 0 0
4 US_TYPE_STDMA 0 0 0 0
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
721194
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
721193
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Philipp
