on 10-05-2023 21:42
I have an issue with my virgin media broadband. I'm approx 4 months into my 500mbps contract and after the first month my speeds have dropped drastically from 500-560mbps to 43mbps. This i believe is a hard cap placed by virgin media as i am a heavy user. Downloading and Uploading 2-3TB a month. I edit YouTube videos and other media types.
There is 'nothing actually wrong' with my line or modem. I believe I have just been hit by virgin medias traffic management / fair usage policy. This has not been confirmed by virgin, but every time i call virgin, the first thing they look at or mention is my usage and they proceed to offer to upgrade me to 1gbps which wont help me been capped or send a technician out, which also will not help in my situation as there's nothing wrong with my equipment.
Over the last 3 months I have gone through phone calls and one technician came out and replaced my hub 5 for a hub 4 (not that, that would help in my case).
I'm at the end of my whits with all this and just want to cancel my contract without any penalty fees.
By the way, if you search 'virgin 40mbps' you will see other people in a similar situation.
What options do i have in this case? as i am not getting the speeds i am paying for.
10-05-2023 21:59 - edited 10-05-2023 22:04
There are no caps / fair usage policies in place with VM.
I've used more than 16.5TB in the last 30 days.
on 10-05-2023 22:51
Hi Carl, I have read the traffic management document. But on speaking to virgin they said they have the right to throttle traffic as its in my terms and conditions.
I have no other explanation for why my speeds are been consistently capped at 43mbps. I am connected by 2m long cat6 cable. if i leave it, and don't use the internet heavy, i am uncapped and able max out my 500mbps plan. Then shortly after hit by the cap again.
Can i ask are you on the 1gig plan? Maybe 1gig users are in a different classification.
10-05-2023 22:56 - edited 10-05-2023 22:57
Yes, I am on Gig1, however there are no policies in place as mentioned.
CS are just trying to upsell a customer that clearly has an issue with their line or equipment.
What does this site show?
https://samknows.com/realspeed/
on 11-05-2023 01:42
on 11-05-2023 10:41
Todays Speeds
on 11-05-2023 19:54
If you access your hub on 192.168.0.1, click the 'Check router status' option (Don't sign in), you should have access to several tabs containing the HUB stats. Can you copy paste this data into several posts so we/VM can review?
on 12-05-2023 01:40
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 0 | 1 |
25 | 331000000 | -0.2 | 32 | QAM256 | 25 |
1 | 139000000 | 2.9 | 30.6 | QAM256 | 1 |
2 | 147000000 | 2.3 | 30.4 | QAM256 | 2 |
3 | 155000000 | 2.4 | 30.4 | QAM256 | 3 |
4 | 163000000 | 2.3 | 30.8 | QAM256 | 4 |
5 | 171000000 | 1.6 | 30.6 | QAM256 | 5 |
6 | 179000000 | 2.1 | 31.2 | QAM256 | 6 |
7 | 187000000 | 1.7 | 30.6 | QAM256 | 7 |
8 | 195000000 | 2 | 31.1 | QAM256 | 8 |
9 | 203000000 | 2.2 | 31.7 | QAM256 | 9 |
10 | 211000000 | 2.2 | 32 | QAM256 | 10 |
11 | 219000000 | 1.9 | 31.4 | QAM256 | 11 |
12 | 227000000 | 1.9 | 31.7 | QAM256 | 12 |
13 | 235000000 | 2.2 | 32.3 | QAM256 | 13 |
14 | 243000000 | 1.9 | 32.2 | QAM256 | 14 |
15 | 251000000 | 1.5 | 30.9 | QAM256 | 15 |
16 | 259000000 | 2 | 32.2 | QAM256 | 16 |
17 | 267000000 | 1.6 | 32.2 | QAM256 | 17 |
18 | 275000000 | 0.7 | 32 | QAM256 | 18 |
19 | 283000000 | 0.7 | 32.2 | QAM256 | 19 |
20 | 291000000 | 0.5 | 32 | QAM256 | 20 |
21 | 299000000 | 0.6 | 32 | QAM256 | 21 |
22 | 307000000 | 0.8 | 32.2 | QAM256 | 22 |
23 | 315000000 | 0.6 | 32.3 | QAM256 | 23 |
24 | 323000000 | 0.1 | 32.3 | QAM256 | 24 |
26 | 339000000 | -0.3 | 32 | QAM256 | 26 |
27 | 347000000 | -0.1 | 32.3 | QAM256 | 27 |
28 | 355000000 | -0.8 | 31.6 | QAM256 | 28 |
29 | 363000000 | -1 | 31.7 | QAM256 | 29 |
30 | 371000000 | -1.3 | 31.3 | QAM256 | 30 |
31 | 379000000 | -1 | 31.4 | QAM256 | 31 |
25 | Locked | 31.993563 | 0 | 0 |
1 | Locked | 30.589052 | 0 | 0 |
2 | Locked | 30.366289 | 0 | 0 |
3 | Locked | 30.420918 | 0 | 0 |
4 | Locked | 30.823864 | 0 | 0 |
5 | Locked | 30.646576 | 0 | 0 |
6 | Locked | 31.201750 | 0 | 0 |
7 | Locked | 30.646576 | 0 | 0 |
8 | Locked | 31.072100 | 0 | 0 |
9 | Locked | 31.688669 | 0 | 0 |
10 | Locked | 31.993563 | 0 | 0 |
11 | Locked | 31.403784 | 0 | 0 |
12 | Locked | 31.688669 | 0 | 0 |
13 | Locked | 32.321487 | 0 | 0 |
14 | Locked | 32.237156 | 0 | 0 |
15 | Locked | 30.884605 | 0 | 0 |
16 | Locked | 32.237156 | 0 | 0 |
17 | Locked | 32.237156 | 0 | 0 |
18 | Locked | 31.993563 | 0 | 0 |
19 | Locked | 32.237156 | 0 | 0 |
20 | Locked | 31.993563 | 0 | 0 |
21 | Locked | 31.993563 | 0 | 0 |
22 | Locked | 32.237156 | 0 | 0 |
23 | Locked | 32.321487 | 0 | 0 |
24 | Locked | 32.321487 | 0 | 0 |
26 | Locked | 31.993563 | 0 | 0 |
27 | Locked | 32.321487 | 0 | 0 |
28 | Locked | 31.615677 | 0 | 0 |
29 | Locked | 31.688669 | 0 | 0 |
30 | Locked | 31.335388 | 0 | 0 |
31 | Locked | 31.403784 | 0 | 0 |
on 12-05-2023 01:40
1 | 43100000 | 43 | 5120 KSym/sec | QAM64 | 2 |
2 | 23600000 | 41.5 | 5120 KSym/sec | QAM64 | 5 |
3 | 30100000 | 42 | 5120 KSym/sec | QAM64 | 4 |
4 | 36600000 | 42.5 | 5120 KSym/sec | QAM64 | 3 |
5 | 49600000 | 43.5 | 5120 KSym/sec | QAM64 | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
6 | 10.0 | 38.2 | 2K | QAM128 |
6 | OFDMA | 200 | 53.9 | 0 | 0 |
on 12-05-2023 01:41
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | kfoA,.iyewrkldJKDHSUBsgvc |
SFID | 252 |
Max Traffic Rate | 575000000 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 251 |
Max Traffic Rate | 38520000 |
Max Concatenated Burst | 16320 |
Scheduling Type | bestEffort |
