louisebattersby
  • 11
Message 1 of 7
35mb download on M350 Fibre Broadband
This has dropped over the past week from 100mb to 35mb, it's getting worse not better. I should be in excess of 350mb.
I can't get through on the phone to report, what can be done on here ? I've dumped the hub info below....what's wrong ?
1139000000937256 qam1
21470000009.337256 qam2
31550000009.337256 qam3
41630000009.337256 qam4
51710000009.837256 qam5
61790000009.537256 qam6
71870000009.437256 qam7
8195000000937256 qam8
9203000000937256 qam9
10211000000937256 qam10
112190000008.837256 qam11
122270000008.537256 qam12
132350000008.437256 qam13
14243000000837256 qam14
15251000000837256 qam15
162590000007.937256 qam16
17267000000837256 qam17
18275000000837256 qam18
192830000008.337256 qam19
202910000008.137256 qam20
212990000008.537256 qam21
22307000000837256 qam22
23315000000837256 qam23
24323000000837256 qam24
1Locked37.62530
2Locked37.62110
3Locked37.31560
4Locked37.6680
5Locked37.6500
6Locked37.6790
7Locked37.6610
8Locked37.6560
9Locked37.3420
10Locked37.6860
11Locked37.61310
12Locked37.6670
13Locked37.61090
14Locked37.31570
15Locked37.62850
16Locked37.3950
17Locked37.62630
18Locked37.6990
19Locked37.3950
20Locked37.31510
21Locked37.31370
22Locked37.61330
23Locked37.31780
24Locked37.31930
louisebattersby
  • 11
Message 2 of 7
Re: 35mb upload on M350 Fibre Broadband
channels
1394000423.425512064 qam9
2462000843.45512064 qam8
3537002473.475512064 qam7
4603001903.5512064 qam6
3ATDMA0000
4ATDMA0000
work Log
20/07/2020 18:20:18noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/07/2020 18:20:3Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/07/2020 09:16:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2020 22:31:3ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2020 22:01:50ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/07/2020 21:51:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/07/2020 15:24:30ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2020 11:11:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/07/2020 23:24:1ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/07/2020 21:42:22ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/07/2020 20:19:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2020 20:18:29ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 22:34:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 16:58:25ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 05:27:13ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/07/2020 17:56:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/07/2020 17:56:4ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 06:13:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2020 05:27:39ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 01:47:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
louisebattersby
  • 11
Message 3 of 7
Re: 35mb download on M350 Fibre Broadband
topic title should be download
  • 24K
  • 2.54K
  • 4.36K
Message 4 of 7
If you think that you have a BB speed problem, then to check the speeds coming in to your Hub properly, and whether they match what you should be getting, you cannot rely on wifi tests, - no BB supplier guarantees those - only speeds "TO" the Hub are guaranteed.
So, can you test speeds directly like this. As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a known good and working Cat5e (or better) ethernet cable, directly to the Hub which you have put into “modem mode”. Test at speedtest.net (not the App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again.
There are many posts on here where unknown software, corrupted browsers or other connected devices are limiting speeds on tests.
Report back what that gets.
louisebattersby
  • 11
Message 5 of 7
I've ran the test on two different laptop devices (ethernet connected and modem mode), using safe mode and normal along with two different browsers, chrome and internet explorer.
The worst is 35mb the best is 102mb, each test fluctuates between these bookends. The upload remains around 34-36mb each time. ping is 28 to 30ms
The reason I have checked the speed is that multiple devices, wired or wifi, are suffering at anytime of the day.
Tags (1)
Anonymous
Not applicable
Message 6 of 7
The power levels on some of your downstream channels are in the upper limits (-6 to +10 is within spec, 0 is considered 'optimal').
I can't see much else to be concerned about, well the 'No Ranging Response received - T3 time-out' errors, however they could be related to the power levels.
Emily_G
  • 4.82K
  • 209
  • 286
Message 7 of 7
Thanks for the post Louisebattersby.
I'll pop you over a private message so we can confirm the power level errors and book an engineer appointment if needed.
Thanks, Emily.
