hughythomas
  • 8
Message 1 of 11
350mbps slowed to only running at 50-70mbps
Heya
Sorry to trouble you with this.
Have been a mostly happy customer for last year or so but recently my connection has dropped to 50-70mbps. I'm not exactly sure when this happened but I certainly have noticed my work uploads are taking forever (let alone trying to stream Youtube videos or even browse internet pages for that matter).
As previously stated, the connection has been very fast previously with game downloads on Steam hitting the 43.5MB/s consistently but now is only reaching 6-8MB/s at best. Clearly, this is a bit of a concern and has cost me a lot of wasted time today at work (WFH).
Things I've done:
  • Rebooted Asus router and access points
  • Rebooted Virgin Hub 3 (normally run it in modem mode)
  • Factory reset Virgin Hub 3
  • Run the virgin diagnostic from Virgin Hub 3 and all passed OK
  • Performed a speedtest on a 2018 Macbook Pro (wired) straight into the Virgin Hub 3 after factory reset...still reporting slow speeds
  • Performed an online Virgin check and all passed OK
  • Checked to see if any problems in my area - none reported by Virgin
Feel like I've exhausted my remedies at home here so am posting to see if I might be able to get some assistance?
Thank you in advance!
Tom
EDIT: I've just gone to see my nextdoor neighbor (who is on the 200Mbps package from Virgin) and he is also experiencing a huge reduction in speed. His speedtest is reporting 30mbps so could be a problem with our cabinet perhaps?
chollerz91
Message 2 of 11
Re: 350mbps slowed to only running at 50-70mbps
I have the same issue at the moment, getting 30mbs and followed all the same steps as you! So annoying!
Buffer6
  • 12.28K
  • 94
  • 652
Hero
Message 3 of 11
You could try a new RJ45 cat6 ethernet cable, sometimes they can get worn or faulty
Login to your Hub and Click on Connected Devices to see what speed your Device
is connected to the Hub
Anonymous
Not applicable
Message 4 of 11
If the neighbour is having a similar issue I can only assume it's an issue with the local area?
chollerz91
Message 5 of 11
Dont think its my cables, been using Cat 8 since install and got very close to my paid service of 350. its just dropped all of a sudden to 30-35mbs now??
hughythomas
  • 8
Message 6 of 11
Heya thanks for taking the time to reply and for your suggestion!
All my cabling is good as I run a music company from home and have to backup large amount(s) of data to various servers around the property. File transfer speeds are lightning quick still its just the internets!
Looks like others are reporting similiar issues so maybe Virgin's network is overloaded?
I'm in the SE of England btw...Surrey to be exact.
hughythomas
  • 8
Message 7 of 11
Speed has returned to normal now.
  • Should we expect further disruptions?
  • Did we get intentionally throttled due to high load?
  • Was it just a one-off technical glitch Virgin's end?
Appreciate these are odd times but some communication would be great!
hughythomas
  • 8
Message 8 of 11
OK so speed is back to being slow again.
I think an explanation from Virgin wouldnt be too much to ask for at this stage (see above).
Anonymous
Not applicable
Message 9 of 11
"I run a music company from home"
then you are breaking the T&C for residential services 😉
hughythomas
  • 8
Message 10 of 11
Useful reply thank you for your valuable insight into my private dealings.
If we could get back onto the topic I'd be very grateful.
