Bebb
350mb/s ben average 42mb/s for past 4+ weeks.
Good AFternoon, having issues with internet for over 4 weeks now, download speeds are terrible under 50mb/s even though contract is 350mb/s. doe various trouble shooting, from virgin help page. changed 2 different etheret cables nothing(these cables works fine tested on 2 different internets) wifi have same terrible speeds, can't be fault in cable. services shows in area all is OK. Router is updated to latest version. got router stats below to look at. had a read forum with similar readings some posts wre answered by admins saying there is issue in line and engineer needs to be called out, will that be the same in my case?
1227000000-1.231256 qam12
2139000000-1.435256 qam1
3147000000034256 qam2
4155000000-132256 qam3
5163000000-0.233256 qam4
6171000000032256 qam5
71790000000.231256 qam6
81870000000.233256 qam7
9195000000-0.433256 qam8
10203000000-0.534256 qam9
11211000000-1.934256 qam10
12235000000036256 qam13
13243000000-0.536256 qam14
142510000000.436256 qam15
15259000000-0.536256 qam16
162670000000.537256 qam17
17275000000-0.736256 qam18
182830000001.437256 qam19
192910000000.436256 qam20
20299000000237256 qam21
213070000001.237256 qam22
223150000002.537256 qam23
233230000001.937256 qam24
1Locked31.411460769484492998
2Locked35.5-16322167851653158
3Locked34.4-98874522020311712
4Locked32.351329707822800983
5Locked34-27280592937624164
6Locked32.6-12526512519133825
7Locked31.971520774711391498
8Locked33.4107758835810165843
9Locked33.4-17203944606773123
10Locked34.3-722390485121600
11Locked34.3-1564214845328496
12Locked36.310956757950601
13Locked36.38205493545773
14Locked36.3213060816339680
15Locked36.66199586643249
16Locked37.32968546638654
17Locked36.32659580247114
18Locked37.32161315963082
19Locked36.61941405747037
20Locked37.61282481130538
21Locked37.6879883324528
22Locked37.6555260525883
23Locked37.3824616016830
18/02/2023 16:40:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2023 16:37:4Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2023 16:36:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2023 16:36:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2023 13:08:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2023 12:57:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2023 12:57:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:21:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:21:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:21:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:21:29Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:21:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:21:20Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:21:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:20:6criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:20:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:20:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:20:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:19:49Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2023 17:19:40criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
can someone help, is there anything else i can do or try to convince Vrigin customer service team that they are wrong and there is issue outside my cables and routers!?
  • 1.87K
  • 116
  • 432
Super solver
Re: 350mb/s ben average 42mb/s for past 4+ weeks.
Looking at the Downstream channels huge numbers of Pre RS and Post Rs errors have been recorded.   Some of the Downstream SNR values are 33 and below which is below the preferred range.
Looking at the Upstream channels only 2 are connected (where 4 or 5 are normal) and the Power level the Hub 3 is transmitting at is too high well above the normal level.   The Hub is working very hard to be heard at the street cabinet.
Check for a known local fault on 0800 561 0061
Failing that a Virgin Media engineer will needed to address the signal levels & SNR issues.
Megan_L
  • 3.9K
  • 219
  • 391
Hi Bebb,
Thanks for using the forums to get this issue with your broadband connection looked into, I am sorry if this has been causing some frustration. I would be more than happy to look into this for you.
I have already checked your services on my side and I can see that your Hub's channels are way out of spec, which means an engineer is needed to visit your home.
I can get this booked in for you over a PM 👨‍🔧 Which I'll gladly send over now!
Speak to you soon.
Megan_L
