jmacp
  • 64
350mb Poor Upload Speed
I am suffering from poor upload speeds seems like there is a brick wall at 6mb.
Can I ask you to check if there any outstanding faults / issues at my area G67.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: 350mb Poor Upload Speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
