computerguy
  • 10
Message 1 of 12
350MB connection unstable, Unifi USG-Pro 4, previously Draytek Vigor, Unifi switching and AP's
tldr: can anyone have a look at the Virgin hub (modem mode) stats at the bottom, and confirm if things are good, or bad?
In more detaul, I think I have a problem with my Virgin connection. Whatever criteria my router is using, the virgin connection apparently fails and flips to the secondary WAN. This casues my users much frustration and gets me alot of emails.
To explain briefly the set up I have, its about 130 users, most with multiple devices. I have two WAN's, Virgin 350mb and a 60mb adsl from elsewhere. Both connect to a Unifi USG Pro 4 (firewall/router/security appliance), which has a LAN connection to a Unifi 24 port switch, which services 15 houses , featuring 15 Unifi AP-Pros, and a number of dumb switches (netgear) which service a few LAN clients.  The Unifi is pretty standard config, no intrusion prevention, just a single LAN, two wans. The Virgin connection is primary, and I get troublesome behaviour whether I choose failover or load balanced mode between the two WANs - it flips between the two all day.
It may be worth noting, I replaced the router today with a Unifi USG pro 4, to be inline with the rest of my equipment, i.e. the core switch and all the AP's. The Unifi appears to handle its assessment of a WAN links connectivity differently, as it seems to see the Virgin link as unstable, and flips to the ADSL connection every 5 minutes. The previous Draytek did not do this, but reports from the user base were poor, in particular web calls, and VPN links for remote workers. I have experienced both issues myself.
My query is not with the LAN set up, but with interpretting the stats from my Virgin hub, and trying to understand the general instability of the Virgin WAN connection overall.
If I put the Virgin hub in standard mode and plug a laptop into it, I see pushing 400Mb. I confess I haven't tested this often, or consistently.
If I take the Virgin WAN out altogether, I get stability in terms of WAN uplink for the LAN users, but the bandwidth isn't enough (60MB down for 100+ users doesn't quite cut it in working from home scenario, unsurprisingly)
As is protocol in this forum, I have collected the upstream/downstream stats from the Virgin hub, which is modem mode, I'll post those below.
I apologise in advance if I have missed any of the basic information required before asking for help. I am happy to provide any further details anyone might like to help troubleshoot this issue.
My questions are:
1) Can anyone advise if there is an obvious problem with the Virgin connection based on the stats below?
2) This is a longshot, can anyone advise why my Virgin hub is inaccessible from the web, which causes the broadband monitor tool to fail, I believe. Previously I used a Draytek Vigor 3300, through which the Virgin public IP was pingable, but now it is not. Worth noting, I can ping the hubs public address from a client on the LAN in one hop. I can't ping it from a separate connection on the web, and the BB monitor just shows dropped packets, 100%. I also cant reach the modem IP from the LAN, and have to plug a laptop directly into it, assign a static in the 192.168.100.1/24 range to reach it. I anticpate the reason for this is out of scope for this forum, but should anyone have a tip, I'd be grateful.
If anyone has experience with opening up the Virgin hub to the internet wiht a USG in front of it, for the sake of the broadband monitor, I'd be eternally grateful, though thats probably a question for the unifi forums.
In the meantime, see below my upstream/downsteam stats and the broadband monitor link as it stands, albeit somewhat useless, from what I can tell.
Upstream:
1 53700000 41.5 5120 64 qam 7
2 46200000 42.5 5120 64 qam 8
3 39400000 43 5120 64 qam 9
4 32600000 43 5120 64 qam 10
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Downstream
1 402750000 11.8 40 256 qam 30
2 202750000 11.3 40 256 qam 9
3 210750000 11.5 40 256 qam 10
4 218750000 11.5 40 256 qam 11
5 226750000 11.8 40 256 qam 12
6 234750000 11.9 40 256 qam 13
7 242750000 11.9 40 256 qam 14
8 250750000 12.1 40 256 qam 15
9 258750000 12.3 40 256 qam 16
10 266750000 12.6 40 256 qam 17
11 274750000 12.6 40 256 qam 18
12 282750000 13 40 256 qam 19
13 290750000 12.9 40 256 qam 20
14 298750000 13 40 256 qam 21
15 306750000 13 40 256 qam 22
16 314750000 13 40 256 qam 23
17 322750000 12.9 40 256 qam 24
18 330750000 12.9 40 256 qam 25
19 370750000 13 40 256 qam 26
20 378750000 13.1 40 256 qam 27
21 386750000 13 40 256 qam 28
22 394750000 12.5 40 256 qam 29
23 410750000 12 40 256 qam 31
24 418750000 12.6 40 256 qam 32
1 Locked 40.3 5 0
2 Locked 40.3 4 0
3 Locked 40.3 8 0
4 Locked 40.3 5 0
5 Locked 40.9 6 0
6 Locked 40.3 6 0
7 Locked 40.3 5 0
8 Locked 40.3 9 0
9 Locked 40.9 9 0
10 Locked 40.3 6 0
11 Locked 40.3 8 0
12 Locked 40.3 7 0
13 Locked 40.3 8 0
14 Locked 40.3 9 0
15 Locked 40.9 7 0
16 Locked 40.3 7 0
17 Locked 40.9 5 0
18 Locked 40.3 7 0
19 Locked 40.3 1 0
20 Locked 40.9 6 0
21 Locked 40.3 15 0
22 Locked 40.3 9 0
23 Locked 40.3 8 0
24 Locked 40.9 3 0
Config page
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID 852656
Max Traffic Rate 402500089
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 852655
Max Traffic Rate 38500089
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
Status page
Cable Modem Status
Item Status Comments
402750000
Locked
Ranged Upstream Channel (Hz)
53700000
Locked
Provisioning State
Online
Broadband monitor BBC link
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/6a2d8d416842ced257385c64744b591ca9b5e74b]My Broadband Ping[/url]
Broadband monitor - direct link
I do thank you for reading this far. I have given this alot of thought, but whatever I try, it appears the Virgin WAN link is the cause. For context, I am an infrastructure engineer, not a network engineer, despite my best efforts.
thanks,
Johnny
Anonymous
Not applicable
Message 2 of 12
Re: 350MB connection unstable, Unifi USG-Pro 4, previously Draytek Vigor, Unifi switching and AP's
Your downstream power levels are all out of spec (-6 to +10 is in spec, 0dB is optimal).
Downstream
This will require an engineer visit to correct, either at the local cabinet, or by fitting one of these between the HUB and cable to the wall socket:
https://www.ebay.co.uk/itm/Technetix-12dB-Forward-Path-Equailiser/233455402135?_trkparms=aid%3D11100...
Your BQM isn't working (You need to enable pinging/echo request).
computerguy
  • 10
Message 3 of 12
Thanks so much for the reply Carl_Pearce.
If you're able to confirm, should I wait for contact here from a Virgin engineer about resolving the power issues, or contact them myself somehow? So far as I can see calling them hasn't been an option for a while.
When you say I should enable ping/echo, you mean I should do that on the hub itself? Before installing the Unifi router/firewall, BQM worked fine, so I expect the new firewall is blocking that. Do you agree?
Anonymous
Not applicable
Message 4 of 12
You have three options:
  • Wait for a VM staff member to reply on here (Currently 5 - 7 days).
  • Text VM on 07533 051 809.
  • Phone customer services on 0345 454 1111.
Yes, I agree a third party piece of equipment will be blocking ping requests. It doesn't matter as such, since we already know of an existing issue (Power levels).
computerguy
  • 10
Message 5 of 12
Thanks for the assistance @carl_pearce. I've got an engineer coming out re: power levels on Saturday.
I've also resolved the BQM to WAN IP firewall problem, which enabled the BQM to work.
I'm not clear entirely which sharing link to post, so theres a few below.
Can anyone advise, is the power level issue likely to be the cause of my latency and periodic packet loss?
My BQM
many thanks,
Johnny
computerguy
  • 10
Message 6 of 12
If anyone can advise how to post the live graph correctly, please do. For now heres a static copy as of now.
Anonymous
Not applicable
Message 7 of 12
BQM is terrible, and shows a problem with the line. The engineer should be able to resolve this, whether it's the power levels or something else at play.
computerguy
  • 10
Message 8 of 12
Thanks again Carl.
Out of interest, whats your relationship to Virgin, are you/were you an engineer/employee or do you just do this out of the kindness of your heart?
all the best,
Johnny
Anonymous
Not applicable
Message 9 of 12
@computerguy wrote:
Thanks again Carl.
all the best,
Johnny
Like quite a few community forum members I don't have any affiliation with VM, other than being a customer.
MrHalfAsleep
  • 2.48K
  • 71
  • 974
Problem sorter
Message 10 of 12
OP needs something far more meaty to connect to the internet IMO.  A bit of cursory maths: on the 60Mb connection his workers are only getting dial-up speeds whereas on the 350Mb they're getting 3.15Mb (mid/late domestic 90's speeds).
We endeavour to be helpful.
The only winning move is not to play.
No system is 100% secure
Ridicule is nothing to be scared of - Adam Ant
The only thing constant - is change. Chris Evans
The internet is a series of tubes
Windows Update isn't rocket science - if it were, it would work.
Unlike Monty Python, spam is never off.
Some video posts may contain swearing/inappropriate content for young children
π
