Rbeck44
Just joined
30mb download speed - paying for 200mbs
I’ve recently “upgraded” to 200mbs. In the last 24 hours the speed hasn’t got over 30mbs with it sometimes going as low as 11mbs. It’s really frustrating!
i have the hub with wifi off and use a mesh system running off that. I have done speed tests both wirelessly and from Ethernet straight out of the Virgin hub. No use. I’ve switch off and back on again, no change.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: 30mb download speed - paying for 200mbs
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
