Simulacra
  • 21
Message 1 of 31
22-25mbps instead of 107mbps promised for M200.
Since tomorrow...
Called to CC, they unable even to identify the problem.
No engineer sent to take a look and fix the issue this year.
I have much time enough to change my mind and change ISP.
I paid a fortune for VM cable; it becomes golden despite all possible deprication.
My initial contract was 27 GBP for 100Mbps. Now I pay more than 42 for 25mbps.
Where the progress came?
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 31
Re: 22-25mbps instead of 107mbps promised for M200.
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 31
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Simulacra
  • 21
Message 4 of 31
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)139000000147000000155000000163000000171000000179000000187000000195000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)1.041.381.401.671.661.731.811.98
RxMER (dB)33.6034.0834.2134.6334.9335.0835.4235.60
Pre RS Errors2007043518624750179040291728130016719300163245111546870214886929
Post RS Errors74402003903044228293414787651139008862200453713282093
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID6534
Frequency (Hz)25800000326000004620000039400000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)51.0051.0051.0051.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts9273
T4 Timeouts0000
General Configuration
Network AccessAllowed
Maximum Number of CPEs1
Baseline PrivacyEnabled
DOCSIS ModeEuroDOCSIS 3.0
Config File
SFID28816
Max Traffic Rate230000061 bps
Max Traffic Burst42600 bytes
Min Traffic Rate0 bps
Primary Upstream Service Flow
SFID28815
Max Traffic Rate22000061 bps
Max Concatenated Burst42600 bytes
Scheduling Type
First TimeLast TimePriorityError NumberDescription
26/12/2020 18:41:12 GMT26/12/2020 18:41:12 GMTWarning (5)66050310Auth Success - Web login successful.
26/12/2020 18:40:29 GMT26/12/2020 18:40:29 GMTWarning (5)66050310Auth Success - Web login successful.
26/12/2020 18:39:06 GMT26/12/2020 18:39:06 GMTWarning (5)66050310Auth Success - Web login successful.
26/12/2020 18:38:07 GMT26/12/2020 18:38:07 GMTWarning (5)66050310Auth Success - Web login successful.
26/12/2020 17:13:32 GMT26/12/2020 17:13:32 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 17:13:31 GMT26/12/2020 17:13:31 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 16:59:56 GMT26/12/2020 16:59:56 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 16:59:55 GMT26/12/2020 16:59:55 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 16:59:44 GMT26/12/2020 16:59:44 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:59:10 GMT26/12/2020 16:59:10 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:57:15 GMT26/12/2020 16:57:15 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:53:26 GMT26/12/2020 16:53:26 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:47:44 GMT26/12/2020 16:47:44 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:46:43 GMT26/12/2020 16:46:43 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:38:46 GMT26/12/2020 16:38:46 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:34:26 GMT26/12/2020 16:34:26 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:34:00 GMT26/12/2020 16:34:00 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:24:56 GMT26/12/2020 16:24:56 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:24:29 GMT26/12/2020 16:24:29 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 16:20:41 GMT26/12/2020 16:20:41 GMTCritical (3)82000200No Ranging Response received - T3 time-out
Simulacra
  • 21
Message 5 of 31
Channel ID12345678
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)1.001.461.401.721.611.761.842.04
Pre RS Errors2014271118684977179594551733262316767394163705991551086514926421
Post RS Errors74520643906922228550214803081140174863095454093282271
Channel ID6534
Mini-Slot Size2222
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts9273
T4 Timeouts0000
Upstream Burst  Req(1) Init Maint(3) Per Maint(4) Adv Short(9) Adv Long(10) Adv UGS(11)
Modulation Type16QAMQPSK16QAM64QAM64QAM16QAM
Differential EncodingOFFOFFOFFOFFOFFOFF
Preamble Length56640384104104104
Preamble Value Offset65200716716716
FEC Error Correction (T)05510165
FEC Codeword Information Bytes (K)1634348122386
Maximum Burst Size0003255255
Guard Time Size84848888
Last Codeword LengthFixedFixedFixedShortenedShortenedShortened
Scrambler On/OffONONONONONON
Config File
SFID28816
SFID28815
Scheduling TypeBest Effort
26/12/2020 18:52:35 GMT26/12/2020 18:52:35 GMTWarning (5)66050310Auth Success - Web login successful.
Simulacra
  • 21
Message 6 of 31
Direct Link to  Live Graph
Simulacra
  • 21
Message 7 of 31
Simulacra
  • 21
Message 8 of 31
Simulacra
  • 21
Message 9 of 31
26/12/2020 22:41:51 GMT26/12/2020 22:41:51 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 22:39:27 GMT26/12/2020 22:39:27 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:38:01 GMT26/12/2020 22:38:01 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:35:27 GMT26/12/2020 22:35:27 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:35:15 GMT26/12/2020 22:35:15 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 22:31:15 GMT26/12/2020 22:31:15 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:31:14 GMT26/12/2020 22:31:14 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:27:59 GMT26/12/2020 22:27:59 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 22:27:36 GMT26/12/2020 22:27:36 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 22:27:12 GMT26/12/2020 22:27:12 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:27:10 GMT26/12/2020 22:27:10 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:26:45 GMT26/12/2020 22:26:45 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 22:20:23 GMT26/12/2020 22:20:23 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 22:18:35 GMT26/12/2020 22:18:35 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:18:03 GMT26/12/2020 22:18:03 GMTCritical (3)82000200No Ranging Response received - T3 time-out
26/12/2020 22:17:35 GMT26/12/2020 22:17:35 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:15:23 GMT26/12/2020 22:15:23 GMTWarning (5)84020200Lost MDD Timeout
26/12/2020 22:15:18 GMT26/12/2020 22:15:18 GMTCritical (3)82000200No Ranging Response received - T3 time-out
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Message 10 of 31
Hello
Looking at the stats there is a problem with the upstream power levels these are close too above the maximum level and will cause some problems with downstream as well, looking at the downstream you have a high number of post RS errors now with all of the above one thing that can cause this is noise on the line and may be resolve by, going around and making sure all coaxial connections to all VM equipment are finger tight best way to do this is too loosen the connector and re-tighten, once that is done power off the hub for 30 secs and back, again check a couple of times in your downstream and if the Post RS errors are rising at a large rate then a VM staff member needs to have a closer look, and maybe you will need an engineer to fix this.
Regards Mike
