iann74
Settling in
Message 1 of 9
20mbps instead of 200. Not minimum guaranteed
Our speeds have not been above 20 for a few weeks now.
Just had a new Hub 3 delivered and it made no difference. It's not the router or the hub.
1331000000340256 qam25
2267000000240256 qam17
32750000001.740256 qam18
42830000001.940256 qam19
52910000001.940256 qam20
62990000002.240256 qam21
73070000002.240256 qam22
83150000002.740256 qam23
93230000003.740256 qam24
103390000002.438256 qam26
11347000000240256 qam27
123550000001.239256 qam28
13363000000240256 qam29
14371000000340256 qam30
153790000003.740256 qam31
163870000004.540256 qam32
17395000000440256 qam33
184030000003.440256 qam34
194110000003.240256 qam35
204190000002.740256 qam36
214270000003.440256 qam37
22435000000440256 qam38
23443000000440256 qam39
244510000004.140256 qam40
1Locked40.31070
2Locked40.32410
3Locked40.32000
4Locked40.32180
5Locked40.32280
6Locked40.31680
7Locked40.32010
8Locked40.31200
9Locked40.9460
10Locked38.91510
11Locked40.92130
12Locked39.35160
13Locked40.91930
14Locked40.31020
15Locked40.3480
16Locked40.9420
17Locked40.9650
18Locked40.3780
19Locked40.3600
20Locked40.3810
21Locked40.3340
22Locked40.3830
23Locked40.9320
24Locked40.311
0
14619997645.3512064 qam11
23940000045.3512064 qam12
35370000045.3512064 qam10
46030001745.3512064 qam9
1ATDMA0020
3ATDMA0010
4ATDMA0020
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
Bsgvca69834ncxv9873254k;f
SFID23299
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID23298
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 9
Re: 20mbps instead of 200. Not minimum guaranteed
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
iann74
Settling in
Message 3 of 9
BQM
Download connection speeds are 10 Mbps at the moment. Upload about the same.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 9
iann74
Settling in
Message 5 of 9
Well... interestingly a ethernet connection to the router (hub is modem only) shows 200Mbps!
I can't see what the connected device speed is.
Is it maybe the QoS?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 9
So are you saying that an ethernet connection speed is OK but Wi-Fi is bad ?
iann74
Settling in
Message 7 of 9
Yes. Turned off QoS and traffic monitor but no change so far.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 9
You need to look at your router !!
Is the Router in DHCP mode ?
Buffer6
  • 12.37K
  • 94
  • 657
Hero
Message 9 of 9
Well... interestingly a ethernet connection to the router (hub is modem only) shows 200Mbps! I can't see what the connected device speed is. Is it maybe the QoS?
You have to switch to router mode temporarily in order to get the connected devices option in the Hub3 menu
