Message 1 of 14
20mb whilst paying for 200mb
  • 17.59K
  • 1.85K
  • 3.06K
Message 2 of 14
Re: 20mb whilst paying for 200mb
More info needed
  • 31.5K
  • 1.65K
  • 5.51K
Message 3 of 14
what speeds do you get wired
  • 7
Message 4 of 14
ive been the same since April  paying for M200 and getting this
  • 6.05K
  • 1.14K
  • 1.6K
Message 5 of 14
Hello
I am afraid that your images cannot be approved as they contain your external IP address which is personal information, that should not be posted on an open public forum as well as being against the forum rules.
Regards Mike
  • 7
Message 6 of 14
  • 9.01K
  • 87
  • 586
Hero
Message 7 of 14
Are you testing with Wi-Fi or a Gigabit enabled device connected with cat5e/6 j45 cable to the VM Hub
  • 7
Message 8 of 14
Gigabit enabled pc wired with the cable that came with the vm hub
  • 12.3K
  • 952
  • 1.58K
Message 9 of 14
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
Mike Robinson
  • 6.05K
  • 1.14K
  • 1.6K
Message 10 of 14
Hello
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Posting the stats by copy and paste will remove all personal information so no breaches.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs (if they are pasted then all personal information is * out) and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amount of data to the hub asking if it still on.
Regards Mike
