scott_O
  • 5
Message 1 of 5
200mb upgrade but slow speed
I upgraded to the 200mb speed a couple of days ago. The speed was above 200 on that day, but it now won’t go over 90mb down.
ive rebooted the hub a few times which didn’t help and I’ve also done a service check which says everything is fine.
anyone any ideas on the issue here?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 5
Re: 200mb upgrade but slow speed
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Emma_C
  • 8.28K
  • 512
  • 560
Message 3 of 5
Hi Scott_O,
Really sorry you've been having some issues with the speeds, this isn't good.
I'd also like to apologise for the delay in getting back in touch. We have been busier than usual.
Are you still having this issue since you posted?
I've had a look into this and can see that you've spoken to the team who have offered a resolution.
I hope this means everything is working fine but if you have any concerns do let us know.
Emma_C - Forum Team
scott_O
  • 5
Message 4 of 5
Hi. We managed to sort it when we rang thanks. Apparently the high speed band was disabled on our router somehow so it was just enabled and now works fine.
Emma_C
  • 8.28K
  • 512
  • 560
Message 5 of 5
Ah, I see.
Glad it's all sorted now for you though.
Pop back if you need anything else.
Emma_C - Forum Team
