TDW
  • 9
Message 1 of 11
200mb slow speed.
Hi all.
 I've had a few speed issues for the last few weeks.  I rang VM and they sent me a new router but the speeds are still really slow.
I should and used to get 200mb but now get 100 if I'm lucky (it's normally 40-70mb)  most times of the day.
My area was oversubscribed in 2017 for most of 2017 and some of 2018.  This was fixed some time ago tho.  Can it happen again? and so quickly?.
anyway I'll paste some things.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/5c7c0f87befdd44a462fb4c6efdd93bfb4cc6448-01-07-2020
12590000000.938256 qam16
2171000000638256 qam5
31790000005.838256 qam6
41870000005.438256 qam7
5195000000538256 qam8
62030000004.838256 qam9
72110000004.538256 qam10
82190000004.138256 qam11
92270000003.738256 qam12
102350000003.438256 qam13
112430000002.738256 qam14
12251000000238256 qam15
132670000001.937256 qam17
142750000003.438256 qam18
15283000000438256 qam19
162910000004.438256 qam20
172990000004.538256 qam21
183070000004.138256 qam22
193150000004.338256 qam23
203230000004.438256 qam24
214507500001.238256 qam25
22458750000138256 qam26
234667500000.738256 qam27
244747500000.538256 qam28
1Locked38.900
2Locked38.900
3Locked38.650
4Locked38.600
5Locked38.650
6Locked38.630
7Locked38.650
8Locked38.950
9Locked38.650
10Locked38.650
11Locked38.6120
12Locked38.600
13Locked37.600
14Locked38.640
15Locked38.960
16Locked38.930
17Locked38.600
18Locked38.900
19Locked38.660
20Locked38.900
21Locked38.950
22Locked38.650
23Locked38.640
24Locked38.900
1394000003.375512064 qam92
2462000003.35512064 qam91
Any help is much appreciated, many thanks.
Edit. Forgot to mention this is a wired connection on cat 6 cable into a gigabit nic.  I do have the router in modem mode normally but tested it in router mode aswell with the same results. thanks.
jb66
  • 12.14K
  • 899
  • 1.75K
Message 2 of 11
Re: 200mb slow speed.
Same speeds on fast.Com?
  • 22.41K
  • 2.4K
  • 3.99K
Message 3 of 11
Do you really only have 2 upstream channels? Should be 4. The 2 power levels are quite low too - albeit in "spec".
TDW
  • 9
Message 4 of 11
Same Speeds on fast.com yep.
TDW
  • 9
Message 5 of 11
Only 2 upstream Channels yes.
  • 22.41K
  • 2.4K
  • 3.99K
Message 6 of 11
Can you try a reset and see if they reappear !
Note that a pinhole reset on a Hub3 can be a bit problematic - so do it EXACTLY this way (not as the VM website says!).
Firstly, make sure the Hub's sticker/card with the two passwords on it is still there and legible or you will be stuffed ! If its not – DON’T DO IT !
With the Hub switched "on", disconnect any ethernet connections and then push in the “reset pin” with the end of a paperclip/thin nail or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT restart the Hub after that. Leave it 10' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub (it is a six digit numeric one).
TDW
  • 9
Message 7 of 11
Thanks for the replies, very much appreciated.
 I’ve done lots of resets as you described, over the last few weeks.
Old router would always just have the 2 channels just like the new one.  I’m pretty sure It’s only ever been 2 channels as long as I can remember.
  • 22.41K
  • 2.4K
  • 3.99K
Message 8 of 11
You do need VM input to comment on why you only have 2 up channels - it's wrong.
They should pick this up here in a few days but sometimes posts get overlooked so its always worth calling in as well. The UK call center is still picking up although patience will be required (!) - tray at 08.00 as that seems the best time.
TDW
  • 9
Message 9 of 11
Will do, thanks for taking the time!.  I’ll wait for a reply here.  Many thanks again.
Melissa_F
  • 2.78K
  • 160
  • 219
Moderator
Moderator
Message 10 of 11
Hi TDW,
Thanks for your posts.
I'm sorry that you're not getting the speeds we'd expect on a wired connection.
I've had a look at the backend of your services again and I'm not able to see anything that would be causing any speed issues.
In regards to only having 2 upstream channels, this wouldn't necessarily cause a problem. Customers used to have 2 upstream channels only, so it sounds like the cabinet hasn't been upgraded to have 4 yet.
As we've done all the necessary checks from our end and you're still not getting the speeds we'd like, I'd like to book a technician visit for you.
Can you pop me a private message with your account number and name?
I'll get a visit arranged.
Melissa
