Crustacean94
  • 5
Message 1 of 10
200Mbps on Gig1 Fibre Broadband
Hi Mike,
I am also getting rubbish speeds from the hub4. Around 200mbps wireless and 345 wired with a cat 6 cable.
Spoke to virgin support today and they said the team wont be able to give wifi boosters until 31st january...
Which do you think would be better to give me close to 1gig speeds. TP link boosters like the post creater showed you or a router with the hub 4 in modem mode. Maybe something like this https://www.amazon.co.uk/TP-Link-MU-MIMO-Wireless-Supports-Parental/dp/B00416PTDW/ref=sr_1_6?dchild=...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: 200Mbps on Gig1 Fibre Broadband
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Crustacean94
  • 5
Message 3 of 10
400mbps mate.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 10
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 10
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 10
@Crustacean94 wrote:
400mbps mate.
Is that to the Hub or the Computer ?
Crustacean94
  • 5
Message 7 of 10
Wired cat 6
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 10
The WAN speed is OK.
Try a different Cat 5e or better spec cable between the Hub and PC.
Crustacean94
  • 5
Message 9 of 10
Hi Mike, Sorry for the long reply. How do i get to my BQM graph i have set up a BQM monitor but am unable to see the links or the graph. Bare in mind i have only just set this up.
Crustacean94
  • 5
Message 10 of 10
Re: 200Mbps on Gig1 Fibre Broadband MY BQM
Tags (1)
