altmartin
  • 11
200Mbps contract - 70 at best commonly between 5-10Mbps
Recently, like the past month been seeing some really poor quality connections over Wired and Wifi devices, often when there are only 1 or 2 active devices.
The virgin Media account stats I have an average speed of 213Mbps. And this was true once... over wifi as well. But not for a while.
Last night I was getting 20mbps at best wired 5 or 6 wireless. step up today while Im writing this and getting 70-85.
22/11/2020 09:12:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 09:08:14Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 09:08:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 09:06:23Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 09:02:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 09:01:15Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 08:56:51noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 08:50:36Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 00:51:14Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 00:51:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 21:30:0Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 21:29:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 21:25:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 21:23:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 21:00:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 21:00:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 19:26:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 18:50:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 18:38:6Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Some stuff there doesn't look good but I haven't a clue what it means.
Tags (1)
altmartin
  • 11
Re: 200Mbps contract - 70 at best commonly between 5-10Mbps
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1419000000-138256 qam32
2203000000338256 qam9
3211000000338256 qam10
42190000002.537256 qam11
52270000002.737256 qam12
62350000002.238256 qam13
72430000002.238256 qam14
8251000000238256 qam15
9259000000238256 qam16
102670000001.538256 qam17
112750000001.738256 qam18
122830000001.238256 qam19
13291000000138256 qam20
14299000000138256 qam21
15307000000138256 qam22
163150000000.237256 qam23
173230000000.537256 qam24
18363000000-0.238256 qam25
19371000000038256 qam26
20379000000-0.538256 qam27
21387000000-0.538256 qam28
22395000000-0.438256 qam29
23403000000-0.738256 qam30
24411000000-0.738256 qam31
1Locked38.617931
2Locked38.9411106
3Locked38.6401109
4Locked37.6342217
5Locked37.636045
6Locked38.637736
7Locked38.643562
8Locked38.645648
9Locked38.924434
10Locked38.922843
11Locked39.320440
12Locked38.621738
13Locked38.622336
14Locked38.621437
15Locked38.919748
16Locked37.622337
17Locked37.620626
18Locked38.618538
19Locked38.919638
20Locked38.919129
21Locked38.918833
22Locked38.618635
23Locked38.921011
24Locked38.620112
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13260003939.3512064 qam5
23939998640.3512064 qam4
34619998141.3512064 qam3
45370012943.8512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Your Pre & Post RS Error counts are quite high.
In an ideal world they would be at zero and stay there. To zero them can you reboot the Hub using this method and then keep an eye on the counts.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check the counts again in an hour or so.
altmartin
  • 11
Cheers, I've set up a BQM account hopefully I will find a bit of time for the reboot method you've ve stated and be able post both later this evening.
Thanks.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
