guitarbloke
  • 30
200Mbps - Incredibly slow WiFi since new Hub 3.0 :-(
Quick background - my wifi speed has always been fine - I've been with VM for a few years now on 200MB and no real issues.
A few months ago I was sent a new Hub 3.0 and since then my wifi speed has become steadily slower and slower.  The new hub has been installed in exactly the same place as the old one (which was also a Hub 3.0).  Nothing else has changed on my network.
Wired (ethernet) connection is ok, I'm hitting between 120-150mbps, which although isn't ideal I'll accept it for now, given that a lot of people (myself included) are working from home.
On WiFi, since the new hub was put in, I've seen my speeds drop continuously and now I'm routinely getting 10-15mbps on a daily basis.  I have managed to workaround the issue for now by using powerline adapters for my home office PC, however all of the mobile devices in the house are suffering from extremely slow connections.
I'll post my logs from the router below.  I note in the Network Log there are a number of of errors - Is there something wrong with the new router or perhaps the configuration?
https://ibb.co/4tBNjy9
https://ibb.co/8Nk0mzH
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: 200Mbps - Incredibly slow WiFi since new Hub 3.0 :-(
guitarbloke
  • 30
Here you go! 🙂
My BQM
guitarbloke
  • 30
Has the BQM info helped shed any light?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Not really, no. You have a lot of latency during the gaming / streaming hours but not much else.
Can you download a free Wi-Fi analyser to a device and check for overlapping 'foreign' Wi-Fi broadcasts and then move yours to clearer areas..
I use this one ...
WiFi Analyzer Premium - Apps on Google Play
wifi-analyser-2
guitarbloke
  • 30
Thanks, I'll give that a try
