Adsen
  • 24
200Mbit receiving less than 1Mbit down at peak
Ok I get that there is a National lockdown on at present but this is a slight performance hit.
back story, I am not the line owner but am currently working from home in IT in Technical Support and relient on this connection though having to work around this at present, but I can report back to them.
Checking other posts this seems to be the details you require, I am posting this at gone 3am so these results are not representive of what is received during the day.
Router has had a Wipe and a reboot which made no difference.
I live in the EX1 area
BMQ Results
Speed Test Result
DOWNLOAD
15.1 Mbps
tbbx1 11.9 Mbps
bursting to 22.6 Mbps
UPLOAD
7.4 Mbps
bursting to 7.7 Mbps
Your Latency: 31 ms  SSL
Router Logs on a Hub 3.
Tags (3)
Adsen
  • 24
Re: 200Mbit receiving less than 1Mbit down at peak
1435000000-737256 qam4
2411000000-6.937256 qam1
3419000000-6.937256 qam2
4427000000-737256 qam3
5443000000-737256 qam5
6451000000-7.237256 qam6
7459000000-7.537256 qam7
8467000000-7.937256 qam8
9523000000-7.537256 qam15
10547000000-7.937256 qam18
11555000000-837256 qam19
12563000000-837256 qam20
13571000000-8.237256 qam21
14579000000-837256 qam22
15587000000-8.237256 qam23
16595000000-7.737256 qam24
17603000000-7.937256 qam25
18611000000-7.737256 qam26
19619000000-7.737256 qam27
20627000000-7.737256 qam28
21635000000-7.737256 qam29
22643000000-7.937256 qam30
23651000000-7.737256 qam31
24659000000-8.237256 qam32
1Locked37.6140
2Locked37.6240
3Locked37.3210
4Locked37.6140
5Locked37.6100
6Locked37.6180
7Locked37.3240
8Locked37.6210
9Locked37.6230
10Locked37.6160
11Locked37.3210
12Locked37.3210
13Locked37.3160
14Locked37.3170
15Locked37.3500
16Locked37.3230
17Locked37.6250
18Locked37.3300
19Locked37.3330
20Locked37.6150
21Locked37.3200
22Locked37.3240
23Locked37.3300
24Locked37.318
0
14620000044.8512064 qam1
22580000043512064 qam4
33260000043.5512064 qam3
43940000044.3512064 qam2
2ATDMA0010
3ATDMA0000
4ATDMA0000
  General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
Adsen
  • 24
SFID573000
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID572999
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
16/01/2021 02:54:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 01:20:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 22:21:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 22:21:34noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 22:20:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 22:20:8Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 22:10:45noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 22:10:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 19:34:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:30:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:30:3criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:29:58Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:29:54criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 00:10:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 00:10:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 00:09:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 00:08:46criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 00:02:41Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 00:02:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Your Downstream Power Levels are too low.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
Adsen
  • 24
This was helpful to know what I am looking out for, I have read between +10 and -6 but around 0 is where I would ideally want to be sitting.
But figure they have just dialled down the Speed until the SNR became stable when the owner on the line spoke to them. but since the SW got knocked out the speed now peaks at 140mbit but seems to be really lossy again, and the downsteam power is hitting the -10s now so I figure it is time for them to really get an engineer involved.
1475000000-9.236256 qam9
2483000000-9.236256 qam10
3491000000-9.436256 qam11
4499000000-9.536256 qam12
5507000000-9.536256 qam13
6515000000-9.436256 qam14
7523000000-936256 qam15
8531000000-936256 qam16
9539000000-936256 qam17
10547000000-9.436256 qam18
11555000000-9.736256 qam19
12563000000-9.736256 qam20
13571000000-9.936256 qam21
14579000000-9.736256 qam22
15587000000-1036256 qam23
16595000000-9.536256 qam24
17603000000-9.536256 qam25
18611000000-9.536256 qam26
19619000000-9.536256 qam27
20627000000-9.436256 qam28
21635000000-9.436256 qam29
22643000000-9.535256 qam30
23651000000-9.735256 qam31
24659000000-1036256 qam32
Zak_M
  • 6.12K
  • 315
  • 544
Good morning @Adsen
Welcome to the forums and thank you once again for your post.
I am sorry to hear that you have had some issues with your broadband.
We are going to need to get an engineer round, however I have seen that you have said you are not the account holder.  Are you able to pass DPA on behalf of the account holder?
Kind regards,
Zak_M
