Just joined
200Mb is not 200Mb
I have had ongoing problemns with the "200Mb" service, which is actually runs between 20 to 30 mbs.
My Meraki AP is connected by Cat 6 cable.
Any ideas?
  • 4.82K
  • 883
  • 1.28K
Re: 200Mb is not 200Mb
Hello
How are you testing speed is it wired or wireless as wireless can vary depending on the band you are connected, interference, signal strength etc
Regards Mike
