Compo1
  • 17
Message 1 of 18
200MB gradually drops to 15mb over an hour period
 I have been having a nightmare most day just trying to stream Netflix.
 I started to do a little bit of investigation and found out that my download speed reduces over a period of 1 hour and can be under 20mb. To cure this i simply reboot the Hub 3 run a speed test and im back upto around the 200mb mark again according to Ookla. Then if i test multiple times over an hour it gets slower every time until it almost grinds to a halt.
 Ive endured these slow speeds for over a month and until i started the test didn't realize how bad it was. All my equipment apart from phones connect via cat6 to a router and then the hub. But ive tried direectly to the hub as well.
 Here is what ive tried to do to resolve it.
 Removed router and connected directly to the hub after a full reset symptoms remain the same connection gradually reduces in speed over time.
 New network card in PC and even swapped the PC out for another no change. At this point the only thing connected to the hub was the single PC no change.
 I seem to of eliminated any of my personal kit been an issue and to me it all points to my Hub 3 having a problem. I dont have the heart to go through ringing Virgin trying to explain all this so can somebody help me please ?
 Been a Virgin customer 25 years seldom ask for any support but at almost £40 for broadband only that isnt working as it should im starting to think the loyalty only goes one way.
Andrew-G
  • 6.96K
  • 1.21K
  • 3.04K
Message 2 of 18
Re: 200MB gradually drops to 15mb over an hour period
Sounds like your hub is losing synchronisation with VM's network gear probably due to noise issues.  When you restart the hub, it renegotiates all 28 channels from scratch, and so works OK, until the noise causes it to lose one or more channels.
Connect to the hub by clicking on this link http://192.168.0.1/  That should pull up the log in page for the hub.  But don't log in, just click on the link "Check router status"  That'll bring up a window with five tabs.  All we need is the contents of the three titled Downstream, Upstream, Network log, and if you can post that as text not screenshots it will help.
Open the Downstream tab.  Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here.  Post that, do the same for the Upstream and Network log.  You'll get an error message when you post the Network log, just click on "post" a second time.
Compo1
  • 17
Message 3 of 18
Thanks for your help Andruser
Downstream
1331000000-338256 qam25
2251000000-2.538256 qam15
3259000000-2.538256 qam16
4267000000-2.938256 qam17
5275000000-2.738256 qam18
6283000000-1.938256 qam19
7291000000-238256 qam20
8299000000-2.438256 qam21
9307000000-238256 qam22
10315000000-238256 qam23
11323000000-2.938256 qam24
12339000000-2.438256 qam26
13347000000-2.940256 qam27
14355000000-3.238256 qam28
15363000000-3.238256 qam29
16371000000-3.238256 qam30
17379000000-3.538256 qam31
18387000000-3.738256 qam32
19395000000-3.538256 qam33
20403000000-438256 qam34
21411000000-438256 qam35
22419000000-4.238256 qam36
23427000000-4.438256 qam37
24435000000-5.238256 qam38
1Locked38.910
2Locked38.960
3Locked38.9120
4Locked38.970
5Locked38.900
6Locked40.350
7Locked38.950
8Locked38.620
9Locked38.950
10Locked38.680
11Locked38.640
12Locked38.940
13Locked40.320
14Locked38.960
15Locked38.9100
16Locked38.6150
17Locked38.9160
18Locked38.6100
19Locked38.9110
20Locked38.670
21Locked38.9130
22Locked38.660
23Locked38.6150
24Locked38.680
Compo1
  • 17
Message 4 of 18
Upstream
1394001464.275512064 qam2
2258000094.275512064 qam4
3325999644.275512064 qam3
4462000264.275512064 qam1
3ATDMA0000
4ATDMA0000
Compo1
  • 17
Message 5 of 18
Network log
08/11/2020 11:31:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 11:30:51Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 22:47:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:38:22ErrorService Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:34:14noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 10:44:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 08:57:19noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 08:55:41Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 08:47:25noticeSW download Successful - Via Config file
07/11/2020 08:45:27noticeSW Download INIT - Via Config file
06/11/2020 16:13:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 00:53:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 00:53:24ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 00:22:41criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 00:22:33criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 00:20:56criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 00:20:48criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 00:19:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 00:19:7criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 00:18:58criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Compo1
  • 17
Message 6 of 18
And this is all im getting at the moment.
This is a good day
https://www.speedtest.net/result/10384166558
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 18
Andrew-G
  • 6.96K
  • 1.21K
  • 3.04K
Message 8 of 18
The network log is full of frequent critical errors, and the downstream power looks as though it is just falling into problem territory.  Whether that's enough to cause the slowdown I don't know, but hopefully the forum staff can comment when they pick up your post.
Compo1
  • 17
Message 9 of 18
Thank for your help i will setup think broadband shortly
How this for £38 quid a month 200mb broadband ? 11.7mb download.
https://www.speedtest.net/result/10385426685
Compo1
  • 17
Message 10 of 18
