MrLiam
  • 16
Message 1 of 7
200MB Slow Speed
Over the last few days my internet speeds appear to have fallen off a cliff. Previously with a Hub2 ac I had issues every few days which could be fixed with a reboot. However around a month ago took up the option of free upgrade to the Hub3. Since moving to the Hub3 I've had no issues until the last 2 days where loading files for work is extremely slow, streaming video on iPlayer / Prime video results in constant buffering and low picture quality.
Checked the online problem checker but this just says my kit is online and no issues in the local area. Speeds tests over wifi showing around 10-15Mb/s Down and 20-21Mb/s up. Connected via cat6 the download improves to around 30Mb/s
The Hub3 is in modem mode connected to my own switch and access point. Any chance someone can looks at the Hub stats to see if something looks wrong?
12990000002.438256 qam21
2139000000138256 qam1
3147000000138256 qam2
41550000001.240256 qam3
51630000001.240256 qam4
61710000001.440256 qam5
71790000001.538256 qam6
81870000001.738256 qam7
91950000001.938256 qam8
10203000000240256 qam9
112110000001.738256 qam10
122190000001.438256 qam11
132270000001.740256 qam12
142350000001.540256 qam13
152430000001.540256 qam14
162510000001.538256 qam15
172590000001.438256 qam16
18267000000238256 qam17
19275000000240256 qam18
202830000002.238256 qam19
212910000002.540256 qam20
223070000002.740256 qam22
233150000002.740256 qam23
243230000002.540256 qam24
1Locked38.690
2Locked38.94523
3Locked38.9390
4Locked40.9300
5Locked40.9320
6Locked40.3480
7Locked38.9490
8Locked38.9430
9Locked38.9360
10Locked40.3490
11Locked38.9310
12Locked38.9180
13Locked40.3110
14Locked40.3250
15Locked40.3360
16Locked38.9290
17Locked38.9190
18Locked38.6150
19Locked40.3110
20Locked38.9120
21Locked40.360
22Locked40.3100
23Locked40.380
24Locked40.380
MrLiam
  • 16
Message 2 of 7
Re: 200MB Slow Speed
Couldn't fit all the details in the original post....
The critical warnings in the network log are from when I was checking connections on the coax cable from the entry point into the house to the Hub3 and don't appear to be a constant occurrence. RCS partial service does seem to crop up every few days though.
1394000314.725512064 qam12
2326000434.725512064 qam13
3462000514.725512064 qam11
4537000214.725512064 qam10
3ATDMA0000
4ATDMA000
0
03/07/2020 08:43:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 18:23:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:56:45criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:55:55Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:55:50criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:55:50Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:55:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:39:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:06:57Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:06:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:06:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:06:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:06:33criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 17:06:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 16:42:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 16:37:55criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 16:35:54criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 16:35:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Andrew-G
  • 6.98K
  • 1.22K
  • 3.05K
Message 3 of 7
If you've been remaking the connections (quite reasonably) then the hub's log won't provide much useful information for that time period.  If you're STILL seeing frequent RCS Partial service, T3 timeouts and synchronisation errors, that's evidence of a problem of some sort, but at the moment most of the hub's figures look OK - as they normally would after a restart.
The breakthrough of post-RS errors early after a restart on channel 2 is a bit of a worry.  I'd suggest waiting until the connection feels slow and lumpy, then check the same data again, in particular Downstream and Upstream, but don't restart the hub before you do that as it clears the error counters and will force the hub to renegotiate any problem channels which can disguise a deeper problem.
MrLiam
  • 16
Message 4 of 7
Strangely what I found yesterday is after rebooting the Hub the connection would get even worse (0.03Mb/s down but up still perfectly fine). Only way to get it to recover to 10Mb/s ish would be to give the coax a dirty disconnect and reconnect which would then get speeds back to around 15Mb/s. Hence all the critical warnings in the log, did think it would be useless including those logs but thought i'd be up front about why they're there.
The speed today even though improved is still a long way off what I'm used to getting so this is still a bumpy time to capture these details right?
MrLiam
  • 16
Message 5 of 7
Didn't need to wait for too long for it to turn dreadful again, back down to 0.36Mb/s over wifi.
Latest Hub stats (with one new entry in network log)...
1299000000238256 qam21
21390000000.738256 qam1
31470000000.538256 qam2
41550000000.740256 qam3
51630000000.940256 qam4
6171000000140256 qam5
71790000001.238256 qam6
81870000001.438256 qam7
91950000001.240256 qam8
102030000001.240256 qam9
112110000001.238256 qam10
122190000001.238256 qam11
132270000001.440256 qam12
142350000001.238256 qam13
15243000000140256 qam14
162510000001.240256 qam15
172590000001.238256 qam16
182670000001.938256 qam17
192750000001.740256 qam18
202830000001.938256 qam19
21291000000240256 qam20
223070000002.240256 qam22
233150000002.238256 qam23
24323000000240256 qam24
1Locked38.990
2Locked38.64623
3Locked38.9640
4Locked40.3470
5Locked40.9340
6Locked40.3480
7Locked38.6500
8Locked38.9440
9Locked40.3390
10Locked40.3490
11Locked38.9310
12Locked38.9240
13Locked40.3140
14Locked38.9270
15Locked40.3360
16Locked40.3300
17Locked38.9190
18Locked38.9150
19Locked40.3120
20Locked38.9120
21Locked40.360
22Locked40.3110
23Locked38.990
24Locked40.3100
3ATDMA0000
4ATDMA0000
03/07/2020 11:34:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 6 of 7
Have you tried removing your own equipment and connecting to the hub directly to test speeds?
MrLiam
  • 16
Message 7 of 7
Cheers Gary
Turned Hub back into router mode and unplugged all my stuff.
Back to normalish (for peak time) speeds. Now for the fun part of working out what's wrong on the LAN.
