uk10eddy
  • 21
Message 1 of 30
200M slowing to less than 10 in evenings
New customer! I have had a 200M connection for a couple of months now, initially very happy but the last few weeks the throttling/contended connection has gotten quite bad slowing to less than 10Mbps.
I have gone through all the available checks using wireless and wired Ethernet connections and both are experiencing slowness.
I am aware that I signed up with a guaranteed minimum download speed of 100...which I am not getting, it’s not good enough, I know I can get the speeds so why am I’m punished into the evening? We can barely stream Netflix in HD let alone 4K.
help me Obi-Wan Kenobi
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 30
Re: 200M slowing to less than 10 in evenings
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 30
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
uk10eddy
  • 21
Message 4 of 30
Hi Mike,
Thank you for you reply, details from the router are as follows...
Downstream
1402750000135256 qam30
2202750000-0.935256 qam9
3210750000-0.735256 qam10
4218750000-0.735256 qam11
5226750000-135256 qam12
6234750000-1.235256 qam13
7242750000-134256 qam14
8250750000-134256 qam15
9258750000-234256 qam16
10266750000-1.234256 qam17
11274750000-0.534256 qam18
12282750000-0.234256 qam19
13290750000035256 qam20
142987500000.234256 qam21
153067500000.734256 qam22
16314750000135256 qam23
17322750000135256 qam24
18330750000135256 qam25
193707500001.934256 qam26
203787500002.235256 qam27
21386750000235256 qam28
223947500001.735256 qam29
234107500000.735256 qam31
244187500000.934256 qam32
1Locked35132700
2Locked3559200
3Locked3584850
4Locked3584460
5Locked35120980
6Locked35124400
7Locked34.9205740
8Locked34.9357030
9Locked34.9319770
10Locked34.3682520
11Locked34.9323380
12Locked34.9204760
13Locked35192640
14Locked34.9294440
15Locked34.9132560
16Locked3575470
17Locked35.526970
18Locked3544730
19Locked34.963920
20Locked3545400
21Locked35.736560
22Locked35.541360
23Locked35203910
24Locked34.9210950
Upstream
14620000051512064 qam6
23260000049.5512064 qam8
33940000049.5512064 qam7
45370000051512064 qam5
2ATDMA0010
3ATDMA0000
4ATDMA0010
uk10eddy
  • 21
Message 5 of 30
Configuration
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cxv9873254k;fg87dsfd;kfoA,.iy
SFID10054
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID10889
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
uk10eddy
  • 21
Message 6 of 30
Network log
03/12/2020 07:59:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2020 18:35:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:00:22ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:54Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/11/2020 04:23:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/11/2020 09:06:34noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/11/2020 09:06:34ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2020 19:52:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 21:06:33noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 21:06:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 20:46:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 12:08:49Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 12:08:43criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 12:08:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 12:08:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 12:07:56Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 12:07:52criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2020 12:07:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I did manage to get through to a nice chap at Virgin this morning who did tell me that everything at my end seemed to be fine and said that there is an issue in the pipeline causing congestion which is on a sort of moderate list of things to get fixed hopefully in the next couple of weeks. Like I said this is only recently started happening in the evenings, usually its nice and fast.
uk10eddy
  • 21
Message 7 of 30
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 30
Did you set up a BQM ?
Two of your Upstream Power Levels are maxed out but still in spec so keep an eye on them.
uk10eddy
  • 21
Message 9 of 30
Yes BQM link in the post above.
Not sure what the maxing out power levels would mean or the cause?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 30
They are drawing the maximum amount of power, any more will start to cause problems on your line.
