Marksy2000
Message 1 of 5
200 to 350 upgrade not applied?
Am I correct that given the downstream in my hub 3 is showing at 230000061 and upstream as 220000061 that my upgrade has not been applied?
jhuk
  • 2.99K
  • 52
  • 286
Problem sorter
Message 2 of 5
Re: 200 to 350 upgrade not applied?
Cant see photo for now (it will appear later) try a reboot of HUB ideally lave it unpowered couple of mins.
gary_dexter
  • 30.26K
  • 1.88K
  • 4.02K
Message 3 of 5
Correct - that’s a 200Mbps config
Marksy2000
Message 4 of 5
Thanks I’ve tried that but still the same 😞
jhuk
  • 2.99K
  • 52
  • 286
Problem sorter
Message 5 of 5
I knew your Config was 200 by numbers you posted above (as i said photo was not showing at that time) but if a reboot did not force the Hub to grab your new Config then you need call them as it may not have bene done yet,
I would not go as far as a Factory Reset of Hub (Pin Hole)_ as that is more to do with forcing a firmware update if it applied in your regions servers but not on your Hub yet, the Config for your Tier is on your account and its grabbed each time the Hub starts up from a reboot.
