irratic
1mb speed
 10 to 15 year old router, speed drops to around 1 to 2 meg every evening and for this i pay nearly £50 a month . Sick of ringing and getting no response.
So what are you going to do about it virgin ? iv really had enough of the terrible service
sophist
  • 2.7K
  • 433
  • 747
Re: 1mb speed
do you get the same speeds when testing using a device connected to the hub over ethernet?
if so, post the stats from your hub...
browse to your hub on  http://192.168.0.1 - don't log in, click Router Status - copy/paste the tables from the Upstream, Downstream and Network Log tabs back to this thread - you'll need multiple posts for this, the info wont all fit into a single one..
it's also worth setting up a BQM - once set up, find the Live Graph and click "Create Sharing Link" - post that back here.
