George87
  • 8
Message 1 of 9
1gig Hub 4 Don't even reach minimum
Hi all.
Been with virgin for a few years now. I had 100mbps until last week when I've changed my package to 1Gig. For the last week a keep trying to reach VM customer service/technical department but absolutely no luck no call backs..
Hope someone can suggest something to me.
As above this is a 1Gig with Hub 4. Solid white light. Can't get more than 500Mbps while wired. Using RJ45 Cat 7 cable which capable up to 10gig. I don't find any other solution.
Now for the last few days my speed between 100Mbps to 350Mbps.
Did multiple restart and on off.
Usually testing on speed net.
The minimum guaranteed is 570Mbps. Unfortunately can't speak to a member of staff. No answer for my complaint via email.
Wifi wifi test sometime better than wired.
Not to mention when I connect to Pure VPN my speed drops under 100Mbps. I guess they not throttling after al...
Some help with the normal speed issue would be much appreciated.
Thanks for any help!
George
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 9
Re: 1gig Hub 4 Don't even reach minimum
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
George87
  • 8
Message 3 of 9
Thanks for the quick answer. Pictures being reviewed so cannot be seen what I previously sent but the link you provided me says
1021 - 280
Using Macbook 13 Air with Usb Network adapter Syncwire USB 3.0 to RJ45 10/100/1000 Gigabit Ethernet Lan Network Adapter and a Cat 7 cable with the same specs with gold plated ends.
Seems my hub gets the full 1 gig but less coming out.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 9
Can you double check the USB to Ethernet adaptor.
280Mbs is about the max speed for a USB 2 adaptor.
Also check the USB port on the Mac.
George87
  • 8
Message 5 of 9
The Macbook is an early 2014 just checked online it has 2 usb 3 port. The adapter also usb 3. I did manage to get 300-400mbps a few days back but not anymore and it's not stable connection.
Please ignore the BQM in my first post as it's the sample picture and I can't find the one I created.
Interestingly different sites gives different numbers.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 9
In the URL box paste the link you copied and in the ‘text to display’ box write My BQM then click OK
George87
  • 8
Message 7 of 9
BQM
George87
  • 8
Message 8 of 9
It could be the adapter or the laptop. My console gets 800mbps.
SCA1972
  • 5.89K
  • 662
  • 2K
Message 9 of 9
It could be the Mac OS as a recent poster has discovered they get slower speeds with Big Sur than they do with Catalina:
https://community.virginmedia.com/t5/Speed/Re-Deteriorating-Broadband-speeds/m-p/4486615#M249366
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
