corky123
  • 30
  • 5
Message 1 of 25
1gb upgrade not as expected, i.e. slow
Hi there,
Yesterday I got my hub 4 and 1gb broadband upgrade, coming from 350mb.
I put it straight into modem mode and ran various speed tests from my server and was disappointed to see I was only getting 500 - 600mb download speed.
my server is connected to a wired gigabyte network, I moved the server next to the hub 4, so server- -my router- - hub 4. I got the same speeds as above, so this ruled out my internal network.
I then put the hub 4 back into router mode and got the same results again.
I then went to the Sam Knows Real speed test web site while connected direct to the hub 4 and the internal speed was more like what I should expect from my server on my network.
I was getting around 936mb download.
So my question is why the massive drop in speed when coming straight out of the hub 4 ?
In testing there is only one small cat 5e cable between the hub 4 and my router, and one more cable to the server.
thanks.
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 2 of 25
Re: 1gb upgrade not as expected, i.e. slow
I would always change cables just to make sure!
-tony-
  • 18.98K
  • 1.44K
  • 3.64K
Message 3 of 25
log into hub3/4 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
____________________
Tony.
Ex VIP
corky123
  • 30
  • 5
Message 4 of 25
Thanks for the quick reply, I did change the main one between the hub 4 and my router.
corky123
  • 30
  • 5
Message 5 of 25
Thanks for the reply, I can’t seem to post the results as it says I have reached 2000 characters
corky123
  • 30
  • 5
Message 6 of 25
When I figure out how to post the results from an iPad I will do.
I can’t copy and paste any of it and add it as it does not like the context, even a small section, and I can only seem to save as a txt file which I can’t attach.
if I could save a photo I would be able to attach.
ewhitey
  • 135
  • 10
Superfast
Message 7 of 25
Hi…I’m having a very similar issue with my 1GB connection except sometimes Im getting 900 odds download to Hub4 but often get 300 to 700 as well…from hub to pc - no other connections, i get around 5-600 mostly. Regards the posting - I think you just ignore the error message on the post and press the same button again if that makes sense!
corky123
  • 30
  • 5
Message 8 of 25
Thanks very much, that worked a treat.
I hope you get your issue resolved as well.
corky123
  • 30
  • 5
Message 9 of 25
3.0 Downstream channels
2633900000012.00000038.605377QAM25626
113900000010.19999738.605377QAM2561
214700000010.19999738.983261QAM2562
315500000010.00000038.605377QAM2563
416300000010.00000038.605377QAM2564
51710000009.80000338.605377QAM2565
617900000010.00000038.605377QAM2566
71870000009.80000338.983261QAM2567
819500000010.00000038.605377QAM2568
92030000009.69999738.605377QAM2569
102110000009.59999838.605377QAM25610
112190000009.09999838.605377QAM25611
122270000008.19999738.605377QAM25612
132350000007.59999838.605377QAM25613
142430000007.69999738.605377QAM25614
152510000007.90000237.636276QAM25615
162590000008.50000038.605377QAM25616
172670000009.09999837.636276QAM25617
1827500000010.09999838.605377QAM25618
1928300000010.30000338.605377QAM25619
2029100000010.59999838.605377QAM25620
2129900000010.50000038.605377QAM25621
2230700000010.40000238.605377QAM25622
2331500000010.90000238.605377QAM25623
2432300000010.90000238.605377QAM25624
2533100000011.59999838.605377QAM25625
2734700000012.19999738.605377QAM25627
2835500000011.59999837.636276QAM25628
2936300000011.09999837.636276QAM25629
3037100000010.59999837.636276QAM25630
3137900000010.00000037.636276QAM25631
26Locked38.60537700
1Locked38.60537700
2Locked38.98326100
3Locked38.60537700
4Locked38.60537700
5Locked38.60537700
6Locked38.60537700
7Locked38.98326100
8Locked38.60537700
9Locked38.60537700
10Locked38.60537700
11Locked38.60537700
12Locked38.60537700
13Locked38.60537700
14Locked38.60537700
15Locked37.63627600
16Locked38.60537700
17Locked37.63627600
18Locked38.60537700
19Locked38.60537700
20Locked38.60537700
21Locked38.60537700
22Locked38.60537700
23Locked38.60537700
24Locked38.60537700
25Locked38.60537700
27Locked38.60537700
28Locked37.63627600
29Locked37.63627600
30Locked37.63627600
31Locked37.63627600
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159964K1880QAM4096759
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked399.2169327940
corky123
  • 30
  • 5
Message 10 of 25
3.0 Upstream channels
13940000043.7705995120 KSym/sec64QAM4
24620000044.2705995120 KSym/sec64QAM3
35370000044.2705995120 KSym/sec64QAM2
46030000045.2705995120 KSym/sec64QAM1
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
