paulovader01
1gb upgrade and Wi-Fi mesh
Have upgraded to the 1gb broadband but not getting anywhere near that on devices indoors.
Now understand a bit more about how it works (thanks to posts on here) but my question is if I upgrade my mesh network to a mesh 6 would that boast our speeds ?
I currently have a BT Whole Home (AC2600) and don’t want to waste more money if it’s not going to make it any better.
Cheers all.
jb66
  • 12.96K
  • 987
  • 1.94K
Re: 1gb upgrade and Wi-Fi mesh
Whats the point though?  What is there to gain from getting 800mb on your phone rather than 450mb?
To benefit from mesh 6 your devices also have to be wifi 6 compatible, Id advise to just use your internet and don't get too bogged down with what speedtests say.
  • 6.08K
  • 511
  • 1.57K
@jb66 wrote:
Whats the point though?  What is there to gain from getting 800mb on your phone rather than 450mb? To benefit from mesh 6 your devices also have to be wifi 6 compatible, Id advise to just use your internet and don't get too bogged down with what speedtests say.
+1   Sage advice 🙂
  • 19.51K
  • 799
  • 2.06K
speed and power😁
Stobbsy74
  • 163
  • 44
Superfast
I get about 850mbps with an Asus wifi6 mesh system and wifi6e gaming laptop.
As the previous posters have stated, the devices that you do large amounts of downloading on need to be wifi6 or better to benefit from it. If you don't have wifi 6 or better devices that you download large files to then not worth it.
For example, Xbox series x is wifi 5 so no benefit, Ps5 is wifi 6 so would benefit, both be better connected via ethernet.
Kath_F
  • 33.66K
  • 1.29K
  • 2.72K
Hi pailovader01,
Thanks for your post and welcome to the Community. It's great having you on board with us in the Community.
I'm sorry to hear you're not getting close to the 1GB speeds on your devices.
As already mentioned, in order to receive the higher speeds, the devices themselves need to be WiFi 6 compatible. If they are not then the speeds will top out at a lower speed than the 1GB.
Running checks at this end, I can see the Hub is receiving the correct speed and is therefore pushing that out. If you connect a PC/Laptop to the hub directly via an ethernet cable, reboot the Hub and re-run the speed test, what speeds do you get? Please bear in mind the ethernet cable will need to be capable of running 1GB speeds and also the network card on your PC/Laptop also needs to be capable and set to the 1GB option.
Let us know so we can investigate further if need be.
Kath_F
