mrbluesky57
  • 31
Message 1 of 34
1gb on hub 4 slow speeds
Just upgraded from 350 to 1GB package with new Hub 4 and only getting 100 to 175 mbps on a  ethernet cable direct to Hub.  slower than my old Hub 3 not happy anything I can do My PC is old but have just upgraded my ethernet adapter made no difference.
Please Help
  • 6.82K
  • 593
  • 1.79K
Message 2 of 34
Re: 1gb on hub 4 slow speeds
You are getting the full speed to the Hub from VM.
How are you testing and on what device.  Are you using a know good Cat 6a cable? Note VM do not guarantee wifi speeds.
If you are using Windows, try testing a direct wired connection using "Safe Mode with Networking support"
mrbluesky57
  • 31
Message 3 of 34
tested with wired connection in safe mode with networking a little better but not much
Cable I'm using is
https://www.amazon.co.uk/gp/product/B08CZJBP75/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
Not sure if that is any good
mrbluesky57
  • 31
Message 4 of 34
Sorry meant to say running 6 year old Win 10 PC updated ethernet adapter which is running at 1.0 gbps
PC was running a lot better/faster on the old 350 speed
carl_pearce
  • 1.77K
  • 114
  • 378
Super solver
Message 5 of 34
Sounds like an odd request, however do you have any wireless devices to test?
I'm wondering if there is a fault with the HUB's ethernet ports.
-tony-
  • 19.22K
  • 1.46K
  • 3.76K
Message 6 of 34
try a different ethernet cable - cat5e or better - flat cables are fine [usually] but have seen more reports of faulty ones than standard cables
____________________
Tony.
Sacked VIP
mrbluesky57
  • 31
Message 7 of 34
tested on a android phone getting 352 mbps
mrbluesky57
  • 31
Message 8 of 34
Have ordered another cable will try it when I get it tomorrow
mrbluesky57
  • 31
Message 9 of 34
New cable  same problem   tested in safe mode with networking
 Not Happy
mrbluesky57
  • 31
Message 10 of 34
please can someone check my data to see if there is a problem many thanks
3.0 Downstream channels
253307500002.79999938.605377QAM25625
81947500003.50000040.946209QAM2568
92027500004.19999740.366287QAM2569
102107500004.19999740.366287QAM25610
112187500003.79999940.366287QAM25611
122267500003.79999940.366287QAM25612
132347500003.90000240.366287QAM25613
142427500004.00000040.366287QAM25614
152507500004.19999740.366287QAM25615
162587500004.00000040.366287QAM25616
172667500003.79999940.366287QAM25617
182747500004.09999840.366287QAM25618
192827500003.59999840.366287QAM25619
202907500003.29999940.366287QAM25620
212987500003.50000040.946209QAM25621
223067500003.40000238.983261QAM25622
233147500003.09999838.605377QAM25623
243227500002.79999938.983261QAM25624
263387500002.70000138.983261QAM25626
273467500002.59999838.983261QAM25627
283547500003.09999838.983261QAM25628
293627500003.20000140.366287QAM25629
303707500003.40000240.366287QAM25630
313787500003.09999840.366287QAM25631
11387500003.90000240.366287QAM2561
21467500004.00000040.946209QAM2562
31547500004.09999840.946209QAM2563
41627500004.00000040.946209QAM2564
51707500003.70000140.366287QAM2565
61787500003.70000140.366287QAM2566
71867500003.50000040.946209QAM2567
25Locked38.60537700
8Locked40.94620900
9Locked40.36628755860
10Locked40.36628700
11Locked40.36628700
12Locked40.36628700
13Locked40.36628700
14Locked40.36628700
15Locked40.36628700
16Locked40.36628700
17Locked40.36628700
18Locked40.36628700
19Locked40.36628700
20Locked40.36628700
21Locked40.94620900
22Locked38.98326100
23Locked38.60537700
24Locked38.98326100
26Locked38.98326100
27Locked38.98326100
28Locked38.98326100
29Locked40.36628700
30Locked40.36628700
31Locked40.36628700
1Locked40.36628700
2Locked40.94620900
3Locked40.94620900
4Locked40.94620900
5Locked40.36628700
6Locked40.36628700
7Locked40.94620900
3.1 Downstream channels
159944K1840QAM1024424
159Locked443.74701157908
