taycar1011
  • 13
Message 21 of 26
Re: 1gb hub 4
Thank you! Much appreciated!
Zak_M
  • 6.12K
  • 315
  • 545
Message 22 of 26
Re: 1gb hub 4
Good morning @taycar1011
How have things been with the 3rd pod now being added?
Kind regards,
Zak_M
taycar1011
  • 13
Message 23 of 26
Re: 1gb hub 4
the third one is 30 feet from the router on the same floor and a wi-fi Speedtest just now clocked 460 standing next to the router and 219 next to the pod.  But I’m not sure what (if anything) can be done about that.
  • 5.93K
  • 494
  • 1.5K
Message 24 of 26
Re: 1gb hub 4
That's how wifi extenders work,  they drop speed on each hop.  Unless they have triband wifi or connected via cable as a backhaul.  I don't think the Pods can do either.
taycar1011
  • 13
Message 25 of 26
Re: 1gb hub 4
It’s not how my upstairs ones are working, which now get faster speeds than they did before the pods were fitted and get far faster speeds than the one mentioned above
Lee_R
  • 5.89K
  • 271
  • 608
Message 26 of 26
Re: 1gb hub 4
Hi taycar1011 thanks for coming back to us.
I am sorry to hear that your WiFi speeds issue is still ongoing.  I would like to take a closer look.  I am going to send you a private message.
Lee_R
