AnthonyG1893
Message 1 of 8
1gb broadband hub 4
Upgraded last year to 1gb broadband.  Got the new hub 4 but never managed to achieve the 1gb either via cable or WiFi... downgraded to 500mbps and went back to my hub 3 instead of the 4 zero issues.... now I'm using the hub 4 and yet again I can't get the speeds promised... so far I've waisted 3 hours on the phone to virgin and zero help.... anyone got any ideas before I look to cancel my contract altogether.
  • 35.1K
  • 3.41K
  • 6.68K
Message 2 of 8
Re: 1gb broadband hub 4
A Hub4 (and Hub3) has wifi5 - it will only ever achieve ~600Mbps on a single device - its just physics.   It can get ~500 on two devices simultaneously - to deliver the ~1GB bandwidth.
To get higher on a single device - you must have wifi6. Note the Hub5 is wifi6 - or you can buy your own equipment.
On cable - test speeds this way...
________________________________
As you expect >100Mbps then.... Connect a 1GB enabled computer/laptop (check network card is set to 1GB) , with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode” (https://www.virginmedia.com/help/virgin-media-hub-modem-mode ).
Or go into the Hub settings and turn off/disable the wifi and also disconnect all ethernet cables from the Hub. This ensures that NO other devices are connected
Test speeds at https://speedtest.samknows.com/ - or https://www.speedtest.net/ - try on 2 different browsers - as Chrome sometimes gives odd results.
If they are still low – boot your device into Windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, anti-virus, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets. For examples of why... see message 7 in the first thread and 9 in in the second and 3 in the third
https://community.virginmedia.com/t5/Speed/HUB-5-and-IGB-wifi/td-p/5088163
https://community.virginmedia.com/t5/Networking-and-WiFi/Slow-Ethernet-Speed/m-p/5060946#M484321
https://community.virginmedia.com/t5/Speed/Upgrade-from-M600-to-Gig1-no-speed-change-with-Hub-4/td-p...
AnthonyG1893
Message 3 of 8
Sorry I gave the wrong info... I have rhe hub 5 which is only pudding out 35mbps up to 254mbps
  • 35.1K
  • 3.41K
  • 6.68K
Message 4 of 8
Do the wired speed test as advised.
Then go into the Hub settings and post up the data from the configuration data page - Downstream and Upstream - particularly the Max Data Transfer Rate info
AnthonyG1893
Message 5 of 8
Great. Thanks for your speedy response
AnthonyG1893
Message 6 of 8
253307500001.437.6QAM25625
61787500003.737.6QAM2566
71867500003.638.6QAM2567
81947500003.537.6QAM2568
92027500003.637.6QAM2569
102107500003.538.6QAM25610
112187500003.238.6QAM25611
122267500002.737.6QAM25612
132347500001.837.6QAM25613
142427500001.437.6QAM25614
15250750000237.4QAM25615
162587500002.838.6QAM25616
172667500003.438.6QAM25617
182747500003.639QAM25618
192827500002.737.6QAM25619
202907500001.337.4QAM25620
212987500000.537.6QAM25621
223067500000.737.6QAM25622
233147500000.437.6QAM25623
243227500000.637.4QAM25624
263387500001.337.6QAM25626
273467500000.737.6QAM25627
283547500001.138.6QAM25628
293627500000.737.4QAM25629
30370750000-0.437.6QAM25630
31378750000-0.437.4QAM25631
323867500000.137.6QAM25632
33394750000-0.237.6QAM25633
34402750000-0.337.6QAM25634
354107500000.237.6QAM25635
364187500000.537.6QAM25636
3.0 Downstream channels
25Locked37.63627600
6Locked37.63627600
7Locked38.60537700
8Locked37.63627600
9Locked37.63627600
10Locked38.60537700
11Locked38.60537700
12Locked37.63627600
13Locked37.63627600
14Locked37.63627600
15Locked37.35598800
16Locked38.60537700
17Locked38.60537700
18Locked38.98326100
19Locked37.63627600
20Locked37.35598800
21Locked37.63627600
22Locked37.63627600
23Locked37.63627600
24Locked37.35598800
26Locked37.63627600
27Locked37.63627600
28Locked38.60537700
29Locked37.35598800
30Locked37.63627600
31Locked37.35598800
32Locked37.63627600
33Locked37.63627600
34Locked37.63627600
35Locked37.63627600
36Locked37.63627600
3.1 Downstream channels
37944K1800QAM4096424
37Locked400.82361518210
Lee_R
  • 6.88K
  • 325
  • 736
Message 7 of 8
Hi @AnthonyG1893  thanks for posting and welcome to our community.
Sorry to hear you're getting slow speeds via your hub 5 and for any inconvenience this may be causing you. I would like to take a look on your behalf. I am going to send you a private message. Please look out for the purple envelope in the top right of your screen.
Lee_R
  • 1.87K
  • 116
  • 432
Super solver
Message 8 of 8
Speed test the service to a router mode Hub + your device with the link below.
The speed at the Hub should reflect your subscription.
