Jongee
  • 6
1MB download, huge packet loss, intermittent connection in RM12 area
Been happening today, it makes my internet unusable so I'm not able to WFH - big issue. Any help would be appreciated as 1MB is simply not enough in this day and age! I'm connected via ethernet as well.
234750000
Locked
Ranged Upstream Channel (Hz)
25799618
Locked
Provisioning State
Online
1234750000-4.738256 qam13
2138750000-8.437256 qam1
3146750000-837256 qam2
4154750000-7.537256 qam3
5162750000-7.237256 qam4
6170750000-6.437256 qam5
7178750000-5.738256 qam6
8186750000-538256 qam7
9194750000-4.738256 qam8
10202750000-4.238256 qam9
11210750000-4.238256 qam10
12218750000-438256 qam11
13226750000-4.238256 qam12
14242750000-4.738256 qam14
15250750000-4.538256 qam15
16258750000-438256 qam16
17266750000-3.738256 qam17
18274750000-3.538256 qam18
19282750000-338256 qam19
20290750000-2.438256 qam20
21298750000-1.538256 qam21
22306750000-138256 qam22
23314750000-0.240256 qam23
243227500000.240256 qam24
1Locked38.9160
2Locked37.3970
3Locked37.3150
4Locked37.390
5Locked37.620
6Locked37.650
7Locked38.6200
8Locked38.650
9Locked38.970
10Locked38.930
11Locked38.980
12Locked38.950
13Locked38.6110
14Locked38.970
15Locked38.960
16Locked38.9140
17Locked38.980
18Locked38.950
19Locked38.970
20Locked38.970
21Locked38.960
22Locked38.950
23Locked40.390
24Locked40.370
1257996185.196512016 qam4
2325991945.2512016 qam3
I also frequently get these T3 timeout issues - which happened even before today.
Andrew-G
  • 6.22K
  • 1.1K
  • 2.64K
Re: 1MB download, huge packet loss, intermittent connection in RM12 area
Your download power levels are all over the place, and well out of spec, and you've only got two upload channels..  If not an area fault that'll need a technician visit to fix, VM forum staff will advise on next steps as soon as they pick up your post (can take a day or three).
Eeeps
  • 757
  • 47
  • 119
Rising star
Whilst your downstream signal levels are too low your post RS error rates look ok.
However, your real problem is in the upstream with only two channels bonded and even these aren't working well.
Has this only got particularly bad today (during the day)?
Is it particularly hot where you are?
As the temperature rises the downstream levels reduce and the level the upstream has to be increased by your modem.
In your case your modem is only just managing to be 'heard' by the VM equipment at the 'exchange'.
You may find your rates improve as it cools tonight.
You'll need an engineer visit to correct those levels.
Jongee
  • 6
Thanks for the insight guys. I'll track the download speeds tonight and tomorrow and see if theres a difference during the day/night as its only May and the days are only going to get hotter and sadly I've got a day job so no option to do the night shift!
If no-one from VM picks this up i'll give them a quick call to see what they say about fixing this.
