waltermorel
  • 24
Message 1 of 8
1Gig stuck at 500
1gig still stuck at 500
Hub4 has been installed for 1Gig update replacing our 500 Meg service but since this morning our broadband is still at 500 Meg speed and our telephone still showing a status “disabled”.
i tried to call customer services with no help.
can someone please help ?
4F4A05EE-E696-4031-A87B-C6719BB19BC9.png2EA0849A-2657-492B-B9F1-F5E9F2CDF3C2.pngC1AC49D0-0A67-4146-9281-D98C282B9CF8.pngBB3A77F3-D467-458D-AB46-43FFCB8D8C74.png08469CB6-79D6-4136-837A-0E33CDC43133.png38C64DFB-51D5-429C-9CD2-A3231840D576.png
thank you
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 8
Re: 1Gig stuck at 500
Your Hub is provisioned for the 1Gbs service.
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Anonymous
Not applicable
Message 3 of 8
Looks like your DOCSIS 3.1 power level is a little low.
waltermorel
  • 24
Message 4 of 8
oh ,
Anything i can do ?
Anonymous
Not applicable
Message 5 of 8
@waltermorel wrote:
oh ,
Anything i can do ?
Other than checking connections are tight nothing you can do.
An engineer visit is required.
As Mike suggested try https://samknows.com/realspeed/ to see what speed you are getting to the HUB.
We are also assuming you are testing on a wired device, not wireless?
Buffer6
  • 12.28K
  • 94
  • 652
Hero
Message 6 of 8
Does your telephone go through the Hub4  or a wall socket?
waltermorel
  • 24
Message 7 of 8
telephone goes through the hub
Zoie_P
  • 3.54K
  • 156
  • 280
Message 8 of 8
Hi Waltermorel,
I am sorry to hear this and I can look into this for you, I will pop you over a private message and take a look for you. Just keep an eye out for the purple envelope.
thanks,
Zoie
