on 28-02-2023 12:27
Hello all,
I recently upgraded my 500Mbit connection with volt to 1Gig and a Hub 5, no big problems.I am wondering however, if it's possible to "tweak" things to get the best out of it .
I started out at 100Mbit and went up the ranks from there and at each stage I noticed the actual download speed exceeded my expectations every time, for the 100Mbit I would regulargy get 130_Mbit speed test results, same at 300Mbit and 500Mbit, each time I would see a good 10+20% on top of the stated figures.
When I saw that the bps links peed on the router was at 138000000Hz on the download channel states I had high hopes for the 1Gig also but.. not really there.
Various speed tests at quite times late at night and during the day have resulted in an average of 840-890Mbit, still plenty fast and well over the minimum guaranteed, but it's not quite there.
So, any tips for squeezing that last few hundred Mbits out?
I'll include my Router stats that I know how to get, if there is any other hidden data you need let me know hot to get it and I'll post it:
Acquired Downstream Channel(Hz) | 138000000 | Locked |
Ranged Upstream Channel(Hz) | 49600000 | Ranged |
Provisioning State | Online | Operational |
1 | 138000000 | -4.3 | 39 | QAM 256 | 1 |
2 | 146000000 | -4.3 | 39 | QAM 256 | 2 |
3 | 154000000 | -4.3 | 39 | QAM 256 | 3 |
4 | 162000000 | -4.3 | 39 | QAM 256 | 4 |
5 | 170000000 | -4.4 | 39 | QAM 256 | 5 |
6 | 178000000 | -4.3 | 40 | QAM 256 | 6 |
7 | 186000000 | -4.1 | 40 | QAM 256 | 7 |
8 | 194000000 | -3.8 | 40 | QAM 256 | 8 |
9 | 202000000 | -3.8 | 40 | QAM 256 | 9 |
10 | 210000000 | -3.5 | 40 | QAM 256 | 10 |
11 | 218000000 | -3.4 | 40 | QAM 256 | 11 |
12 | 226000000 | -3.4 | 40 | QAM 256 | 12 |
13 | 234000000 | -3.3 | 40 | QAM 256 | 13 |
14 | 242000000 | -3.4 | 40 | QAM 256 | 14 |
15 | 250000000 | -3.6 | 41 | QAM 256 | 15 |
16 | 258000000 | -3.7 | 41 | QAM 256 | 16 |
17 | 266000000 | -3.2 | 41 | QAM 256 | 17 |
18 | 274000000 | -3.1 | 41 | QAM 256 | 18 |
19 | 282000000 | -2.9 | 41 | QAM 256 | 19 |
20 | 290000000 | -2.9 | 41 | QAM 256 | 20 |
21 | 298000000 | -3 | 41 | QAM 256 | 21 |
22 | 306000000 | -3.1 | 41 | QAM 256 | 22 |
23 | 314000000 | -3.1 | 41 | QAM 256 | 23 |
24 | 322000000 | -3.2 | 41 | QAM 256 | 24 |
25 | 330000000 | -3.3 | 41 | QAM 256 | 25 |
26 | 338000000 | -3.2 | 40 | QAM 256 | 26 |
27 | 346000000 | -3.4 | 41 | QAM 256 | 27 |
28 | 354000000 | -3.7 | 40 | QAM 256 | 28 |
29 | 362000000 | -3.5 | 41 | QAM 256 | 29 |
30 | 370000000 | -3.6 | 40 | QAM 256 | 30 |
31 | 378000000 | -3.5 | 40 | QAM 256 | 31 |
1 | Locked | 39 | 3353177 | 2216 |
2 | Locked | 39 | 17351067 | 6779 |
3 | Locked | 39 | 3681 | 1699 |
4 | Locked | 39 | 3588 | 1815 |
5 | Locked | 39 | 3513 | 1033 |
6 | Locked | 40 | 5290 | 2014 |
7 | Locked | 40 | 1506 | 1396 |
8 | Locked | 40 | 1304 | 1364 |
9 | Locked | 40 | 1166 | 1559 |
10 | Locked | 40 | 1745 | 1890 |
11 | Locked | 40 | 1754 | 1562 |
12 | Locked | 40 | 1952 | 2899 |
13 | Locked | 40 | 678 | 633 |
14 | Locked | 40 | 1349 | 1498 |
15 | Locked | 41 | 1140 | 1601 |
16 | Locked | 41 | 892 | 1338 |
17 | Locked | 41 | 396 | 539 |
18 | Locked | 41 | 952 | 1493 |
19 | Locked | 41 | 879 | 1345 |
20 | Locked | 41 | 2306 | 1642 |
21 | Locked | 41 | 2925 | 1688 |
22 | Locked | 41 | 2230 | 1041 |
23 | Locked | 41 | 3485 | 1809 |
24 | Locked | 41 | 2625 | 1560 |
25 | Locked | 41 | 2374 | 1417 |
26 | Locked | 40 | 807 | 478 |
27 | Locked | 41 | 1037 | 1175 |
28 | Locked | 40 | 573 | 542 |
29 | Locked | 41 | 1201 | 1345 |
30 | Locked | 40 | 469 | 495 |
31 | Locked | 40 | 689 | 912 |
0 | 49600000 | 56 | 5120 | QAM 64 | 1 |
1 | 43100000 | 55.8 | 5120 | QAM 64 | 2 |
2 | 36600000 | 55.3 | 5120 | QAM 64 | 3 |
3 | 30100000 | 55.3 | 5120 | QAM 64 | 4 |
4 | 23600000 | 54.5 | 5120 | QAM 64 | 9 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
General Configuration
Allowed |
1 |
Enabled |
3.1 |
cmreg-vmdg660-bbt076-b.cm |
158076 |
1230000450 bps |
42600bytes |
0 bps |
Primary Upstream Service Flow
158075 |
55000270 bps |
42600bytes |
0 bps |
42600bytes |
Best Effort |
Answered! Go to Answer
on 28-02-2023 12:44
A single 1000Mb/s or 1Gb/s network connection has a transfer limit of about 940Mb/s.
To reach the full 1140Mb/s speed on a single device the connection is going to have to be made at 2.5Gb/s.
This perhaps means adding a 2.5Gb/s network adaptor to the computer.
As the computer is already topping out at 840-890Mb/s there may not be any more speed to be had.
If your VM Hub is in Router mode this link will show the service speed at the Hub : https://www.samknows.com/realspeed/
on 28-02-2023 12:38
Thought I'd include the Log
28-02-2023 10:21:03 | notice | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:19:06 | notice | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:18:57 | notice | CM-STATUS message sent. Event Type Code: 22; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:17:06 | notice | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:17:06 | notice | CM-STATUS message sent. Event Type Code: 4; Chan ID: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1. |
28-02-2023 10:17:06 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;C |
28-02-2023 10:17:06 | notice | CM-STATUS message sent. Event Type Code: 20; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:17:06 | notice | CM-STATUS message sent. Event Type Code: 23; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:16:39 | warning | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:16:16 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:16:11 | warning | MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:16:06 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:16:05 | warning | MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-02-2023 10:16:05 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 14:58:30 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
27-02-2023 14:58:22 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 14:58:10 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 14:58:08 | notice | Honoring MDD; IP provisioning mode = IPv4 |
27-02-2023 14:58:01 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 14:57:56 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 14:57:43 | critical | Cable Modem reboot from UI |
27-02-2023 14:43:28 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 14:43:17 | critical | Cable Modem Reboot due to power button reset |
27-02-2023 13:20:42 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 13:20:27 | critical | DHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 13:20:26 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 13:13:21 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 13:11:17 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 13:11:17 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 13:11:13 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-02-2023 13:11:00 | critical | Cable Modem Reboot due to SW Upgrade |
27-02-2023 13:04:34 | critical | Cable Modem Reboot from SNMP |
on 28-02-2023 12:44
on 28-02-2023 12:47
Interesting, thank you very much for the info, soo.... the hub seem to be right on the money speed wise, it's my dinosaw networking kit that needs a revamp..... OK, That I can do, thanks!
on 28-02-2023 14:15
Just as a side note, I unplugged the network cable and used wifi... got 1109Mbit heh.
28-02-2023 20:18 - edited 28-02-2023 20:20
I'd suggest your upstream power levels are a touch high, which could be causing an inconsistent connection.
You wouldn't really expect to see any, maybe the odd one, 'Post RS Errors' either.
on 28-02-2023 20:36
on 28-02-2023 20:44
I did a reboot at 6pm and this was the download report at 8:40pm
1 | Locked | 39 | 15 | 0 |
2 | Locked | 39 | 14 | 1 |
3 | Locked | 39 | 0 | 0 |
4 | Locked | 40 | 1 | 0 |
5 | Locked | 40 | 1 | 0 |
6 | Locked | 40 | 1 | 0 |
7 | Locked | 40 | 2 | 0 |
8 | Locked | 40 | 8 | 10 |
9 | Locked | 40 | 1 | 0 |
10 | Locked | 40 | 7 | 0 |
11 | Locked | 40 | 5 | 13 |
12 | Locked | 40 | 7 | 9 |
13 | Locked | 41 | 19 | 0 |
14 | Locked | 41 | 12 | 0 |
15 | Locked | 41 | 0 | 0 |
16 | Locked | 41 | 0 | 0 |
17 | Locked | 41 | 1 | 0 |
18 | Locked | 41 | 9 | 0 |
19 | Locked | 41 | 0 | 0 |
20 | Locked | 41 | 0 | 0 |
21 | Locked | 41 | 0 | 0 |
22 | Locked | 41 | 0 | 0 |
23 | Locked | 41 | 1 | 0 |
24 | Locked | 41 | 1 | 0 |
25 | Locked | 41 | 0 | 0 |
26 | Locked | 41 | 0 | 0 |
27 | Locked | 41 | 0 | 0 |
28 | Locked | 41 | 0 | 0 |
29 | Locked | 41 | 0 | 0 |
30 | Locked | 41 | 0 | 0 |
31 | Locked | 41 | 1 | 0 |
on 28-02-2023 20:48
VM will respond to this thread in a few days, and will advise if an engineer visit is required.
For now you are getting a least decent speeds.
on 28-02-2023 22:05
