1Gig speed keeps droping to 50 megs
iveivan
Hi, I have a 1 Gig speed connection, diretly connected to pc, usually is 950 megs, but now in the past week keeps droping to 50 60 megs, I restart hub 4 so many times a day now, it  works for a bit then there we go again, is really bad. What is going on?
I has some issues months ago engineer came around checked all cables, hub all fine and no solution was given and speed was better for a while now same issues.
1 ACCEPTED SOLUTION
Accepted Solutions
Hey iveivan, thank you for reaching out and I am sorry to see you are having random drop in speeds.
Thank you for sending these screenshots over they are really helpful.
What I would like do is go through some further checks with you via a PM, would this be okay?
Please look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
26 REPLIES 26
iveivan
3.0 Downstream channels
84670000004.437.4QAM2568
14110000005.937.4QAM2561
24190000005.639QAM2562
34270000005.438.6QAM2563
44350000005.338.6QAM2564
5443000000535.8QAM2565
64510000004.838.6QAM2566
74590000004.737.6QAM2567
94750000004.637.6QAM2569
104830000004.736.6QAM25610
114910000004.737.6QAM25611
124990000004.938.6QAM25612
135070000005.339QAM25613
145150000005.438.6QAM25614
155230000005.538.6QAM25615
165310000005.738.6QAM25616
175390000005.738.6QAM25617
185470000005.938.6QAM25618
19555000000638.6QAM25619
20563000000639QAM25620
215710000006.238.6QAM25621
225790000006.238.6QAM25622
235870000006.138.6QAM25623
245950000006.138.6QAM25624
256030000005.937.6QAM25625
266110000005.737.6QAM25626
276190000005.738.6QAM25627
286270000005.637.6QAM25628
296350000005.737.6QAM25629
306430000005.737.6QAM25630
316510000005.837.6QAM25631
8Locked37.3559887453260
1Locked37.3559886722270
2Locked38.9832617363300
3Locked38.6053777602550
4Locked38.6053775564800
5Locked35.779911750474106604
6Locked38.6053777876960
7Locked37.6362767633920
9Locked37.6362766469730
10Locked36.6096537708910
11Locked37.6362767063010
12Locked38.60537700
13Locked38.98326100
14Locked38.60537710
15Locked38.60537700
16Locked38.60537700
17Locked38.60537700
18Locked38.6053771557850
19Locked38.60537700
20Locked38.983261204710
21Locked38.60537700
22Locked38.60537770
23Locked38.60537700
24Locked38.60537710
25Locked37.63627600
26Locked37.63627600
27Locked38.60537700
28Locked37.63627610
29Locked37.63627610
30Locked37.63627600
31Locked37.63627600
3.1 Downstream channels
159964K1880QAM4096759
159Locked40455717190
iveivan
3.0 Upstream channels
125800000425120 KSym/sec64QAM6
23260000042.55120 KSym/sec64QAM5
33940000042.55120 KSym/sec16QAM4
446200000435120 KSym/sec64QAM3
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
iveivan
Just dropped again, 20 megs! I restarted my modem 6 times now in 1 hour
Its a bit worrying that one up channel has dropped to 16qam and there are lots of PostRS errors on one down channel (5).
Can you do this...
_________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes.
When all done, check back in the settings and ensure that the RS error counts and any T3 errors have all reset to 0. Also that all 4 Up channels are at 64qam. Then check every hour or so to see if the errors start reappearing - they shouldn't. If they do (particularly any PostRS and T3 ones) you have a problem (noise) that only a Tech visit will sort
________________________
Also
If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
iveivan
84670000003.837.6QAM2568
14110000005.839QAM2561
34270000005.238.6QAM2563
44350000004.838.6QAM2564
54430000004.438.6QAM2565
64510000004.137.6QAM2566
74590000004.138.6QAM2567
9475000000437.4QAM2569
104830000004.337.6QAM25610
114910000004.537.4QAM25611
124990000004.637.6QAM25612
13507000000538.6QAM25613
145150000005.138.6QAM25614
155230000005.438.6QAM25615
165310000005.538.3QAM25616
185470000005.838.6QAM25618
205630000005.938.6QAM25620
215710000006.138.6QAM25621
235870000006.237.4QAM25623
24595000000637.6QAM25624
266110000005.637.6QAM25626
276190000005.737.6QAM25627
286270000005.537.6QAM25628
296350000005.637.6QAM25629
306430000005.637.6QAM25630
316510000005.737.6QAM25631
8Locked37.636276345820
1Locked38.98326196060
2Locked38.983261170130
3Locked38.605377527120
4Locked38.60537767350
5Locked38.605377111010
6Locked37.636276216320
7Locked38.605377387510
9Locked37.35598864910
10Locked37.636276124450
11Locked37.355988175230
12Locked37.63627600
13Locked38.60537710
14Locked38.60537700
15Locked38.60537700
16Locked38.25775500
17Locked38.60537700
18Locked38.605377159960
19Locked38.60537700
20Locked38.605377340
21Locked38.60537710
22Locked38.60537700
23Locked37.35598800
24Locked37.63627600
25Locked37.63627600
26Locked37.63627600
27Locked37.63627600
28Locked37.63627610
29Locked37.63627600
30Locked37.63627600
31Locked37.63627600
159Locked393.958361280
iveivan
12580000041.55120 KSym/sec64QAM6
23260000042.35120 KSym/sec64QAM5
33940000042.85120 KSym/sec16QAM4
44620000043.35120 KSym/sec64QAM3
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
Matt - Forum Team
New around here?
Hi Matthew,
I just sent you a PM, if you can help me would be great.
iveivan
Latest prints:
14110000006.234.5QAM2561
24190000006.138.6QAM2562
34270000005.739QAM2563
44350000005.538.6QAM2564
54430000005.234.5QAM2565
64510000004.934QAM2566
74590000004.837.6QAM2567
84670000004.537.6QAM2568
94750000004.634QAM2569
104830000004.733.5QAM25610
124990000004.937.6QAM25612
135070000005.138.6QAM25613
145150000005.238.6QAM25614
165310000005.638.6QAM25616
175390000005.838.6QAM25617
185470000005.937.6QAM25618
195550000006.138.6QAM25619
205630000006.238.6QAM25620
215710000006.438.6QAM25621
225790000006.538.6QAM25622
235870000006.538.6QAM25623
245950000006.337.6QAM25624
256030000006.237.4QAM25625
26611000000637.6QAM25626
276190000005.937.6QAM25627
28627000000637.6QAM25628
29635000000637.4QAM25629
30643000000637.6QAM25630
316510000006.137.4QAM25631
1Locked34.48357010323324272925
2Locked38.60537730072860
3Locked38.98326132308850
4Locked38.60537731825370
5Locked34.48357011149214189409
6Locked33.95650915569263743520
7Locked37.63627631422270
8Locked37.63627631111370
9Locked33.95650914004383901459
10Locked33.48654215730553727968
11Locked37.63627631430010
12Locked37.63627600
13Locked38.60537700
14Locked38.60537700
15Locked38.60537710
16Locked38.60537700
17Locked38.60537730
18Locked37.6362766026930
19Locked38.60537700
20Locked38.6053772910750
21Locked38.60537710
22Locked38.60537720
23Locked38.60537700
24Locked37.63627610
25Locked37.35598810
26Locked37.63627610
27Locked37.63627650
28Locked37.63627610
29Locked37.35598800
30Locked37.63627620
31Locked37.35598840
159Locked394.5596950960
