cartledgelj
  • 11
Message 1 of 23
1Gig less reliable than 500mb
I took the plunge a couple of weeks back to go from 500mb to the 1Gig line and I have had frequent issues of connection instability and persistent speed variances. I have spoken to the virgin media team on three occasions which results in restarting the router several times with a short uplift in performance, has anyone else had similar issues, if so how did you rectify the problem.
I have seen a few occasions on here where the speed test and stats from the router are asked for so they are provided below, TIA for any help with rectifying this issue.
My last three SamKnows tests are as follows:
Hub 4
Computer
229
532
156
289
171
384
Tags (1)
cartledgelj
  • 11
Message 2 of 23
Re: 1Gig less reliable than 500mb
My downstream and upstream figures are as follows:
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
330750000
13.000000
40.366287
QAM256
25
1
138750000
10.900002
38.605377
QAM256
1
2
146750000
10.699997
38.605377
QAM256
2
3
154750000
10.699997
38.983261
QAM256
3
4
162750000
10.699997
38.983261
QAM256
4
5
170750000
10.800003
38.983261
QAM256
5
6
178750000
10.699997
38.605377
QAM256
6
7
186750000
11.099998
38.983261
QAM256
7
8
194750000
11.000000
38.983261
QAM256
8
9
202750000
10.900002
38.605377
QAM256
9
10
210750000
10.599998
38.983261
QAM256
10
11
218750000
10.800003
38.983261
QAM256
11
12
226750000
11.400002
38.983261
QAM256
12
13
234750000
11.800003
38.983261
QAM256
13
14
242750000
11.400002
40.366287
QAM256
14
15
250750000
10.900002
38.983261
QAM256
15
16
258750000
10.199997
38.983261
QAM256
16
17
266750000
10.500000
38.983261
QAM256
17
18
274750000
11.500000
39.397190
QAM256
18
19
282750000
12.199997
40.366287
QAM256
19
20
290750000
12.599998
40.366287
QAM256
20
21
298750000
13.400002
40.366287
QAM256
21
22
306750000
13.699997
40.366287
QAM256
22
23
314750000
13.699997
40.366287
QAM256
23
24
322750000
13.400002
38.983261
QAM256
24
26
338750000
12.000000
40.366287
QAM256
26
27
346750000
11.800003
40.366287
QAM256
27
28
354750000
12.000000
40.366287
QAM256
28
29
362750000
12.099998
40.946209
QAM256
29
30
370750000
12.199997
40.946209
QAM256
30
31
378750000
11.900002
40.366287
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
40.366287
0
0
1
Locked
38.605377
0
0
2
Locked
38.605377
0
0
3
Locked
38.983261
0
0
4
Locked
38.983261
0
0
5
Locked
38.983261
0
0
6
Locked
38.605377
0
0
7
Locked
38.983261
0
0
8
Locked
38.983261
0
0
9
Locked
38.605377
0
0
10
Locked
38.983261
0
0
11
Locked
38.983261
0
0
12
Locked
38.983261
0
0
13
Locked
38.983261
0
0
14
Locked
40.366287
0
0
15
Locked
38.983261
0
0
16
Locked
38.983261
0
0
17
Locked
38.983261
0
0
18
Locked
39.397190
0
0
19
Locked
40.366287
0
0
20
Locked
40.366287
0
0
21
Locked
40.366287
0
0
22
Locked
40.366287
0
0
23
Locked
40.366287
0
0
24
Locked
38.983261
0
0
26
Locked
40.366287
0
0
27
Locked
40.366287
0
0
28
Locked
40.366287
0
0
29
Locked
40.946209
0
0
30
Locked
40.946209
0
0
31
Locked
40.366287
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
35
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
35
Locked
41
6.7
42079893
65634
cartledgelj
  • 11
Message 3 of 23
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
38.020599
5120 KSym/sec
16QAM
1
2
53700000
38.020599
5120 KSym/sec
16QAM
4
3
32600000
38.020599
5120 KSym/sec
16QAM
3
4
39400000
38.020599
5120 KSym/sec
16QAM
2
0
0
0
0
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
114378
Max Traffic Rate
1230000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
114377
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Paulina_Z
  • 4.36K
  • 161
  • 331
Message 4 of 23
Hi @cartledgelj,
Welcome to our Community Forums! Thank you for your first post, and I'm sorry to hear that you've been experiencing some connection and speed issues ever since you upgraded to the 1Gig. We understand that this must be very frustrating for you and we're happy to look into this further.
I was able to locate your account on our systems, and look through your upstream power levels to ensure that they are within spec. Unfortunately, I can see that your downstream power levels are not where they should be. In order to rectify this issue, we would need to arrange for a technician appointment, as we are unable to resolve this problem remotely.
In order to arrange for an appointment, I will need to confirm some details with yourself. I will send you a Private Message which you can access by locating the purple envelope at the top right corner of your Forum page. I will be in touch soon. 🙂
Thank you.
Paulina_Z
Paulina_Z
  • 4.36K
  • 161
  • 331
Message 5 of 23
Hi @cartledgelj,
Thank you for coming back to me via private message and confirming your details. I have now booked you a technician visit for your speed and connection issue – you can check and amend the date and time via your online account.
There will be no charge for this visit unless:
•    The technician diagnoses the faults as not being caused by our network/equipment
•    The technician discovers that the fault or problem relates to your equipment
•    The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
Thank you.
Paulina_Z
cartledgelj
  • 11
Message 6 of 23
I have now had two engineers out in the last few days, the first engineer fixed the issue with the signals, however this has not made any difference. The second engineer has just left and has confirmed that the signals are spot on, however after running, samknows and ookla speed tests the results are still far below guaranteed (420mb on Ookla and 58.6 on samknows).
The engineer today, checked with one of his colleagues and there is a known issue which is still being investigated related to the Hub4 and 1Gig connections at least in the Northwest/Liverpool area, as it is still very early days the CS teams do not know anything about it. But the engineers I spoke to today are going to chase it up with the network team to see if they are any closer to the bottom of the issue.
Tom_F
  • 4.22K
  • 250
  • 537
Message 7 of 23
Thanks for keeping the thread updated cartledgelj. I've taken a look this morning and as things stand no wider area faults have been raised - however this can take some time.
I can see the hub has been swapped and the power levels do look much better, there are very minimal signs of congestion but nothing close to what we'd need to see to get this raised at the moment.
Please let us know when you've heard back from the engineer - and in the meantime keep your thread updated with network logs/bqm results to try and help us identify what might be causing this now the hub has been swapped.
Tom
cartledgelj
  • 11
Message 8 of 23
I'm not sure how you can see that the hub has been swapped because it hasnt, the engineer that attended did not have a hub 4 never mind the hub 5 which was supposedly ordered.
carl_pearce
  • 1.44K
  • 94
  • 317
Knows their stuff
Message 9 of 23
Tom
The QAM level on the upstream channels indicates an issue, that hasn't been mentioned as yet (Should be 64):
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
38.020599
5120 KSym/sec
16QAM
1
2
53700000
38.020599
5120 KSym/sec
16QAM
4
3
32600000
38.020599
5120 KSym/sec
16QAM
3
4
39400000
38.020599
5120 KSym/sec
16QAM
2
cartledgelj
  • 11
Message 10 of 23
So another update after a third technician came to visit the issue is believed to be between the cabinet and the house, a new cable run is scheduled for 1st Feb. I am unsure why this was not picked up by the first or second engineer or even if this new cable will rectify the issue. Fingers crossed and watch this space.
