apbliv
  • 25
Message 1 of 29
1Gig downloads slower than previous M600
About 2 weeks ago I upgraded to 1Gbps. I was previously on M600 and getting consistently over 550mbps downloads. I installed the Hub4, and every since have been getting slower downloads. I read on here that the Hub4 can take time to settle, so I have waited (in vain). The previous SH3 had a 10 db inline attenuator, which I have kept. I run the Hub4 in modem mode, but if I run it as a hub and then run samknows with my PC directly connected to the Hub4 by Cat6 I get this:
It seems my speed to the hub 4 is fine, but the hub 4 then gives me a lower speed than I got from my SH3 on M600 (by about 20%). Other speed checkers confirm that I cannot get more than ~440 mbps to a wired connection. The upload speed is consistently at expected level.
Hub4 data in next post
apbliv
  • 25
Message 2 of 29
Re: 1Gig downloads slower than previous M600
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
-0.1
39
QAM256
1
2
147000000
-0.3
39
QAM256
2
3
155000000
-0.8
39
QAM256
3
4
163000000
-1
39
QAM256
4
5
171000000
-1.2
39
QAM256
5
6
179000000
-1.4
39
QAM256
6
7
187000000
-1.7
39
QAM256
7
8
195000000
-1.9
39
QAM256
8
9
203000000
-2
38.6
QAM256
9
10
211000000
-2.2
39
QAM256
10
11
219000000
-2.4
38.6
QAM256
11
12
227000000
-2.7
38.6
QAM256
12
13
235000000
-2.7
38.6
QAM256
13
14
243000000
-2.8
38.6
QAM256
14
15
251000000
-2.9
38.6
QAM256
15
16
259000000
-2.9
38.6
QAM256
16
17
267000000
-2.7
39
QAM256
17
18
275000000
-2.2
38.6
QAM256
18
19
283000000
-2
39
QAM256
19
20
291000000
-2.1
39
QAM256
20
21
299000000
-2.7
39
QAM256
21
22
307000000
-3.4
38.6
QAM256
22
23
315000000
-4.1
38.6
QAM256
23
24
323000000
-4.2
37.6
QAM256
24
25
331000000
-4.1
38.6
QAM256
25
26
339000000
-3.8
38.6
QAM256
26
27
347000000
-3.7
39
QAM256
27
28
355000000
-3.9
38.6
QAM256
28
29
363000000
-3.4
37.6
QAM256
29
30
371000000
-3
39
QAM256
30
31
379000000
-3
39
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.983261
0
0
2
Locked
38.983261
0
0
3
Locked
38.983261
0
0
4
Locked
38.983261
0
0
5
Locked
38.983261
0
0
6
Locked
38.983261
0
0
7
Locked
38.983261
0
0
8
Locked
38.983261
0
0
9
Locked
38.605377
0
0
10
Locked
38.983261
0
0
11
Locked
38.605377
0
0
12
Locked
38.605377
0
0
13
Locked
38.605377
0
0
14
Locked
38.605377
0
0
15
Locked
38.605377
0
0
16
Locked
38.605377
0
0
17
Locked
38.983261
0
0
18
Locked
38.605377
0
0
19
Locked
38.983261
0
0
20
Locked
38.983261
0
0
21
Locked
38.983261
0
0
22
Locked
38.605377
0
0
23
Locked
38.605377
0
0
24
Locked
37.636276
0
0
25
Locked
38.605377
0
0
26
Locked
38.605377
0
0
27
Locked
38.983261
0
0
28
Locked
38.605377
0
0
29
Locked
37.636276
0
0
30
Locked
38.983261
0
0
31
Locked
38.983261
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
159
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
159
Locked
37
-10.1
514235361
0
apbliv
  • 25
Message 3 of 29
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
40.5
5120 KSym/sec
64QAM
13
2
39400000
41
5120 KSym/sec
64QAM
12
3
46200000
41.5
5120 KSym/sec
64QAM
11
4
53700000
42.5
5120 KSym/sec
64QAM
10
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
0
0
2
US_TYPE_STDMA
0
0
3
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
1
0
Any advice on how to improve things would be much appreciated. The SH3 has gone back, so I can't re-install that to get higher download speeds.
Alan
Akua_A
  • 2.9K
  • 71
  • 188
Message 4 of 29
Hi @apbliv,
Welcome back to our community forums.
Sorry to hear you are having issues with your broadband speeds.
Have you tried rebooting your device to see if the problem persists? Have you also tried changing your Ethernet cord to see if the issue remains?
Please let us know how you get on.
Akua_A
apbliv
  • 25
Message 5 of 29
Hi Akua_M
thanks for the reply. I have tried rebooting, switching between modem and hub mode and different cables. I will try a rest at some point, but I don't hold out much hope that will make a difference. Everything is the same as when I had M600 with a SH3 in modem mode, but the download speed is slower.
Best regards
Alan
Akua_A
  • 2.9K
  • 71
  • 188
Message 6 of 29
Thanks for getting back to us @apbliv.
Is the speed still slow in safe mode? Is it also slow in modem mode?
Also please let us know how the reset goes.
Many thanks,
Akua_A
Anonymous
Not applicable
Message 7 of 29
I'd suggest that your DOCSIS 3.1 channel needs an adjustment on power level:
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
159
Locked
37
-10.1
514235361
0
You could try removing the attenuator, however this will increase the other channels power levels, as well as affect upstream power, which could knock them out of spec!
apbliv
  • 25
Message 8 of 29
Thanks to those who made some suggestions. I have been a bit busy the last few days, but managed to rest the Hub4 and then test it with and without the 10dB attenuator.
Samknows got worse!
Hub Mode after reboot with 10dB attenuator (17 Mar 2021)
Channel
Channel Width (MHz)
FFT Type
159
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
159
Locked
38
-9.6
806400
0
Channel
Channel Width (MHz)
FFT Type
159
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
159
Locked
39
1.3
3826518
2863
I then set the Hub 4 to modem mode and Speedtest gave me this with and without the attenuator - back to ~500Mbps.
To test my local network I download a 6Gb movie file from my NAS and got these speeds:
My NAS does other things like monitor CCTV, but the transfer indicates I can get 1Gig speeds on my wired network.
So, I suspect the Hub is the issue. Maybe I need to sit a fan underneath it as someone else has suggested. I will have time to phone VM next week which may be the best way to solve this.
Alan
Chris_W1
  • 4.62K
  • 207
  • 303
Message 9 of 29
Hi Alan, I am sorry to hear that you are having issues with the connection. I have arranged for an engineer to check this for you and the appointment can be viewed in the online account ^Chris
apbliv
  • 25
Message 10 of 29
Thanks for organising the technician. He duly arrived and tested things.
He confirmed 1Gig to the Hub 4 but then found, as I did, that the speed to my PC was half that in modem mode through my Asus router, but SLOWER if the PC was directly connected to the Hub4 in hub mode using his Cat6 cable.
He found that download speed discrepancy odd and agreed to try a new Hub4, but that had the same effect. He left bemoaning the fact that VM do not supply their tech staff with a device that can confirm the speed coming out of the Hub4 when directly connected to it. He had no further suggestions other than it must be my equipment on the basis two hubs gave the same result. However, he could not demonstrate that the Hub4 delivered 1 gig.
The delay in posting this response is because I have been busy. I have replaced two 10-year-old NetGear gigabit switches with new ones, and also replaced Cat5 cables with Cat6 - the last one from the ground floor room where the Hub4 is up to my 2nd floor office today. These upgrades have changed nothing as regards download speeds from the Hub 4. My office laptop (HP Elitebook 840G5) typically downloads at ~300 Mbps on a wired connection (it gets 97 MBps file transfer from my NAS drive on the ground floor indicating the Cat6 is working). My Pixel 4a phone just got 450mbps (!) through wifi (I have a Mesh Wi-Fi network with Ethernet wired backhaul).
Something is throttling download speeds, but I am at a loss to work out what.
Alan
