on 26-10-2023 13:08
Hi, I have had the 1Gig service for just over 6 months. I had reliable got the upload speed of approx 52mbps and I then got the upgrade to 100mbps which worked fine for a while.
Then a few weeks ago I had to upload a large file for work and noticed the speed was reduced. I did a SamKnows RealSpeed test and my upload speed is now consistently hovering around 10-15mbps.
I have contacted Virgin Media about it several times. The first time I was asked to do a full rest of the Hub 5, which had no effect. The next time I was sent a new Hub 5, which has also made no difference.
There are no issues in the area that I can see so I'm wondering what my next steps are? Is this likely to require an engineer visit?
When you contact Virgin Media, everything seems geared around download speed issues and I spend half my time trying to explain that my download speeds are fine, it's not a WiFi issue etc and it's quite frustrating!
on 26-10-2023 15:24
Lets see the Hub data
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 26-10-2023 17:59
Hi, thank you so much for replying to this and for the detailed instructions. Hopefully this is the right info. I'd be interested to know what I'm looking for in future 🙂
1 | 331000000 | 3.6 | 37 | QAM 256 | 25 |
2 | 139000000 | 3.2 | 36 | QAM 256 | 1 |
3 | 147000000 | 3.2 | 36 | QAM 256 | 2 |
4 | 155000000 | 3.3 | 37 | QAM 256 | 3 |
5 | 163000000 | 3.3 | 37 | QAM 256 | 4 |
6 | 171000000 | 3.3 | 37 | QAM 256 | 5 |
7 | 179000000 | 3.4 | 36 | QAM 256 | 6 |
8 | 187000000 | 3.5 | 37 | QAM 256 | 7 |
9 | 195000000 | 3.8 | 36 | QAM 256 | 8 |
10 | 203000000 | 3.8 | 37 | QAM 256 | 9 |
11 | 211000000 | 4 | 37 | QAM 256 | 10 |
12 | 219000000 | 4 | 37 | QAM 256 | 11 |
13 | 227000000 | 4 | 37 | QAM 256 | 12 |
14 | 235000000 | 4 | 37 | QAM 256 | 13 |
15 | 243000000 | 3.9 | 37 | QAM 256 | 14 |
16 | 251000000 | 3.8 | 37 | QAM 256 | 15 |
17 | 259000000 | 3.8 | 37 | QAM 256 | 16 |
18 | 267000000 | 3.9 | 36 | QAM 256 | 17 |
19 | 275000000 | 3.9 | 37 | QAM 256 | 18 |
20 | 283000000 | 3.9 | 37 | QAM 256 | 19 |
21 | 291000000 | 4 | 37 | QAM 256 | 20 |
22 | 299000000 | 3.9 | 37 | QAM 256 | 21 |
23 | 307000000 | 3.9 | 37 | QAM 256 | 22 |
24 | 315000000 | 3.8 | 37 | QAM 256 | 23 |
25 | 323000000 | 3.7 | 38 | QAM 256 | 24 |
26 | 339000000 | 3.7 | 37 | QAM 256 | 26 |
27 | 347000000 | 3.7 | 37 | QAM 256 | 27 |
28 | 355000000 | 3.8 | 37 | QAM 256 | 28 |
29 | 363000000 | 3.9 | 37 | QAM 256 | 29 |
30 | 371000000 | 3.9 | 38 | QAM 256 | 30 |
31 | 379000000 | 4.1 | 37 | QAM 256 | 31 |
1 | Locked | 37 | 1 | 0 |
2 | Locked | 36 | 0 | 0 |
3 | Locked | 36 | 1 | 0 |
4 | Locked | 37 | 1 | 0 |
5 | Locked | 37 | 1 | 0 |
6 | Locked | 37 | 0 | 0 |
7 | Locked | 36 | 0 | 0 |
8 | Locked | 37 | 0 | 0 |
9 | Locked | 36 | 0 | 0 |
10 | Locked | 37 | 0 | 0 |
11 | Locked | 37 | 1 | 0 |
12 | Locked | 37 | 0 | 0 |
13 | Locked | 37 | 0 | 0 |
14 | Locked | 37 | 0 | 0 |
15 | Locked | 37 | 0 | 0 |
16 | Locked | 37 | 0 | 0 |
17 | Locked | 37 | 0 | 0 |
18 | Locked | 36 | 0 | 0 |
19 | Locked | 37 | 0 | 0 |
20 | Locked | 37 | 0 | 0 |
21 | Locked | 37 | 0 | 0 |
22 | Locked | 37 | 0 | 0 |
23 | Locked | 37 | 0 | 0 |
24 | Locked | 37 | 0 | 0 |
25 | Locked | 38 | 0 | 0 |
26 | Locked | 37 | 1 | 0 |
27 | Locked | 37 | 0 | 0 |
28 | Locked | 37 | 1 | 0 |
29 | Locked | 37 | 1 | 0 |
30 | Locked | 38 | 0 | 0 |
31 | Locked | 37 | 0 | 0 |
0 | 60300000 | 49.5 | 5120 | QAM 64 | 9 |
1 | 53700000 | 49 | 5120 | QAM 64 | 10 |
2 | 46200000 | 49.5 | 5120 | QAM 64 | 11 |
3 | 39400000 | 49.5 | 5120 | QAM 64 | 12 |
4 | 32600000 | 49 | 5120 | QAM 64 | 13 |
5 | 23600000 | 49 | 5120 | QAM 64 | 14 |
0 | ATDMA | 0 | 7 | 0 | 0 |
1 | ATDMA | 0 | 7 | 0 | 0 |
2 | ATDMA | 0 | 7 | 0 | 0 |
3 | ATDMA | 0 | 7 | 0 | 0 |
4 | ATDMA | 0 | 7 | 0 | 0 |
5 | ATDMA | 0 | 7 | 1 | 0 |
26-10-2023 18:08:38 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
26-10-2023 18:08:38 | warning | Dynamic Range Window violation |
26-10-2023 16:57:05 | warning | Dynamic Range Window violation |
26-10-2023 16:57:05 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
26-10-2023 14:17:20 | warning | Dynamic Range Window violation |
26-10-2023 14:17:20 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
26-10-2023 14:14:20 | warning | Dynamic Range Window violation |
26-10-2023 14:14:20 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
26-10-2023 13:46:03 | warning | Dynamic Range Window violation |
26-10-2023 13:46:03 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
26-10-2023 10:40:41 | warning | Dynamic Range Window violation |
26-10-2023 10:40:41 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
26-10-2023 07:49:57 | warning | Dynamic Range Window violation |
26-10-2023 07:49:57 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
26-10-2023 06:34:05 | warning | Dynamic Range Window violation |
26-10-2023 06:34:05 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
26-10-2023 03:19:02 | warning | Dynamic Range Window violation |
26-10-2023 03:19:02 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
26-10-2023 02:28:29 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
25-10-2023 16:27:46 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
25-10-2023 16:27:46 | warning | Dynamic Range Window violation |
25-10-2023 16:11:27 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
25-10-2023 16:11:27 | warning | Dynamic Range Window violation |
25-10-2023 15:11:33 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
25-10-2023 15:11:33 | warning | Dynamic Range Window violation |
25-10-2023 12:28:29 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
25-10-2023 12:28:29 | warning | Dynamic Range Window violation |
25-10-2023 12:09:50 | warning | Dynamic Range Window violation |
