@dux wrote:
new to 1Gig and seem to be getting extremely low speeds. very underwhelmed.
Any recommendations on what to do would be very welcome.
Have a ASUS mesh coming off the router which has worked well on improving coverage
Put the router in router mode and check what speed do you get on https://samknows.com/realspeed/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
- Make sure the cable is Cat 5e or better
- Make sure your PC/laptop has a 1Gbps or better network card
- Make sure Hub is in router mode
- Disconnect all other Ethernet cables when running the test
