jonnymc4
  • 26
  • 5
Message 1 of 16
1Gig Speed Woes - Not Receving 500 mbps
Hi, I had 1Gig upgraded on Friday and was supplied with a new Hub 4. I've hardwired my laptop using its gigabit port and the maximum speed I have generated since Friday has been no more than 500 mbps. I've read through some other threads and I have rebooted, hard reset using the pinhole, switched off/on. I can't connect to www.samknows.com/realspeed using any browser in router mode so can't tell what I'm receiving at the router. Here are my router stats:
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
Tags (3)
jonnymc4
  • 26
  • 5
Message 2 of 16
Re: 1Gig Speed Woes - Not Receving 500 mbps
3.0 Downstream channels
263387500009.09999840.946209QAM25626
11387500008.90000240.946209QAM2561
21467500008.80000340.366287QAM2562
31547500008.69999740.946209QAM2563
41627500008.30000340.946209QAM2564
51707500007.80000340.366287QAM2565
61787500007.69999740.946209QAM2566
71867500007.59999840.946209QAM2567
81947500007.69999740.946209QAM2568
92027500008.00000040.946209QAM2569
102107500008.19999740.366287QAM25610
112187500008.59999840.366287QAM25611
122267500008.80000340.946209QAM25612
132347500009.09999840.366287QAM25613
142427500009.40000240.946209QAM25614
152507500009.30000340.946209QAM25615
162587500009.50000040.946209QAM25616
172667500009.40000240.946209QAM25617
182747500009.19999740.946209QAM25618
192827500008.69999740.946209QAM25619
202907500008.90000240.946209QAM25620
212987500009.19999740.946209QAM25621
223067500009.30000340.946209QAM25622
233147500009.19999740.946209QAM25623
243227500008.59999840.366287QAM25624
253307500009.00000040.946209QAM25625
273467500009.00000040.946209QAM25627
283547500009.19999740.946209QAM25628
293627500009.09999840.366287QAM25629
303707500009.30000340.946209QAM25630
313787500009.30000340.946209QAM25631
26Locked40.94620900
1Locked40.94620900
2Locked40.36628700
3Locked40.94620900
4Locked40.94620900
5Locked40.36628700
6Locked40.94620900
7Locked40.94620900
8Locked40.94620900
9Locked40.94620900
10Locked40.36628700
11Locked40.36628700
12Locked40.94620900
13Locked40.36628700
14Locked40.94620900
15Locked40.94620900
16Locked40.94620900
17Locked40.94620900
18Locked40.94620900
19Locked40.94620900
20Locked40.94620900
21Locked40.94620900
22Locked40.94620900
23Locked40.94620900
24Locked40.36628700
25Locked40.94620900
27Locked40.94620900
28Locked40.94620900
29Locked40.36628700
30Locked40.94620900
31Locked40.94620900
jonnymc4
  • 26
  • 5
Message 3 of 16
3.1 Downstream channels
159964K1880QAM4096759
159Locked4310.0219134180
3.0 Upstream channels
14620000042.0205995120 KSym/sec64QAM3
23260000043.7705995120 KSym/sec64QAM5
33940000043.2705995120 KSym/sec64QAM4
45370000042.2705995120 KSym/sec64QAM2
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
jonnymc4
  • 26
  • 5
Message 4 of 16
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
;kfoA,.iyewrkldJKDHSUBsgvca69
SFID
17345
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
5193
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
Thu Jan 1 00:01:23 19703No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:03:08 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:03:08 20223Registration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:03:08 20224T6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:03:08 20223REG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:03:35 20223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:04:01 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:04:16 20226SW Download INIT - Via Config file v9873254k;fg87dsfd;kfoA,.
Fri Jan 7 18:07:28 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:07:28 20224Disruption during SW download - Power Failure
Fri Jan 7 18:07:41 20226SW Download INIT - Via Config file a69834ncxv9873254k;fg87dsfd;k
Fri Jan 7 18:09:09 20226SW download Successful - Via Config file
Fri Jan 7 18:11:40 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:14:44 20226CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:37:11 20224DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 18:37:11 20226DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 19:35:03 20224DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 19:35:03 20226DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri Jan 7 23:45:10 20226CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat Jan 8 21:39:10 20223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat Jan 8 22:56:15 20226CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Jan 9 16:25:06 20223SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Jan 9 16:25:06 20226CM-STATUS message sent. Event Type Code: 2; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Jan 9 16:25:12 20225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Jan 9 16:25:58 20226CM-STATUS message sent. Event Type Code: 4; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Jan 9 16:30:49 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Jan 9 19:21:29 20226CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Jan 9 23:03:01 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Jan 9 23:20:38 20226CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Jan 9 23:24:43 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
theboywonder
  • 63
Message 5 of 16
I feel your pain - exactly the same issue I have.
Was on 500mb Friday and got full speed. Upgraded to 1gig and Hub 4 Saturday and cannot get more than 120mb, often 80mb.
  1. SamKnows doesnt work for me either (in router or modem mode)
  2. I have factory reset twice - no difference
  3. I'm connected via Cat6 cable directly to the hub (same setup/equipment with 500mb service and got full speed so it isn't my equipment)
  4. I just finished a call with 150 who...
    1. advised the hub is fine and connected at 1gig (which the hub logs suggested is true) so do not need engineer visit
    2. cannot explain why I got full speed on 500mb service, but slower speeds on the 1gig
    3. couldn't explain why SamKnows doesnt work
    4. suggested it might be external issue with the fibre (but realised this isnt the case as i got 500mb before without issue)
    5. said i can complain to ofcom if the speed is not as expected for 3 consecutive days - I dont want compensation - I want the right speed
    6. asked me to factory reset again and they will monitor for 24 hours
    7. or i cancel as I am the 14 days cooling off period and get the 500mb circuit back, and get a different contract.
To me, if the hub says it is getting 1gig and my hardwired device isn't, then the hub must have an issue (hardware/firmware). I'd at least expect the 500mb speed previously on the same device.
Seems the forum is full of issue with the combination of Hub4/1gig - but I also know people who get full speed!
So frustrating. Hoping a forum moderator and shed some light and investigate too!
jonnymc4
  • 26
  • 5
Message 6 of 16
Here's a snapshot of some of my recent speedtests and my BQM from the last couple of hours:
I'm going to try and reboot again later as I'm leaving the house now. So far it's looking pretty dire, the speedtests are all over the place.
j0s
  • 12
Message 7 of 16
I have the same issue, I get 1 gig to the modem apparently but to my PC it's terrible. I was using modem mode, but currently in router mode and hardwired.
j0s
  • 12
Message 8 of 16
I have the same issue, I get 1 gig to the modem apparently, but to my PC it's terrible. I was using modem mode, but currently in router mode and hardwired.
jonnymc4
  • 26
  • 5
Message 9 of 16
Here's the actual BQM from today.
Screenshot 2022-01-10 at 17-48-16 Broadband Quality Monitor thinkbroadband.png
jonnymc4
  • 26
  • 5
Message 10 of 16
Here is the BQM over a 24 hour period (minus my IP address from the previous post!). I was playing Call of Duty around 9-10pm and it was lagging really badly.
Screenshot 2022-01-11 at 08-58-49 Broadband Quality Monitor thinkbroadband.png
