IbnAbu
  • 6
Message 1 of 10
1Gig - Not getting the Full speed
HI, Since i have upgraded to the 1 Gig Speed I have been getting an average of 700. even downloads don't not seem to go above like 500.
last week for some reason got even worse i was only downloading at 3MB on some downloads.
IbnAbu
  • 6
Message 2 of 10
Re: 1Gig - Not getting the Full speed
i have also taken a Sam knows test. what could be causing this. PLease help
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 10
The WAN supply is correct,
The 80Mbs from Hub to PC is a concern.
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
IbnAbu
  • 6
Message 4 of 10
i have 1 computer connected through ethernet and that is 1000Mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 10
Can you try a different Cat 5e or better ethernet cable between the Hub and PC and test again please.
IbnAbu
  • 6
Message 6 of 10
OKay. i have now got a new Cat 5e ethernet cable and big improvement on samknows test.
The only thing is i still do not get 1g on the speed tests.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 10
If you have any other devices connected to the Hub including Wi-Fi connected devices they will be using some of the bandwidth.
Anonymous
Not applicable
Message 8 of 10
Check task manager for CPU usage when performing speed tests.
IbnAbu
  • 6
Message 9 of 10
Thanks for not closing this post guys. Been busy.
So I have been looking around and its seems to be working now. I stumbled upon a post on the Superuser forum and its seems that the line “Receive Window Auto-Tuning Level” was set to disabled.
I fixed my speeds by changing that setting from Disabled to Normal using this line in CMD:
"netsh int tcp set global autotuninglevel=normal"
Now I'm getting speeds over 900. I still have no idea how that may have gotten disabled. I'm not sure if its because 1am in the morning but I shall check the speeds again when its busy tomorrow, just to confirm if its fixed.
IbnAbu
  • 6
Message 10 of 10
Tried it with the old Ethernet cable and still getting the same speeds >900Mbps... Woooop!
So yeah its seems that the “Receive Window Auto-Tuning Level” toggle actually fixed this issue.
Thank You for the help guys.
