jackjj
  • 12
Message 1 of 22
1Gig Hub4 30Mb average
It's been many days since I noticed that the online movie speed is particularly slow, and when I checked the speed I found that it was only an average of 30Mb. (Yesterday only average 15Mb) In the past, I had tested it and it was around 1000Mb, so I don't know what's wrong.
Tags (1)
  • 20.5K
  • 828
  • 2.2K
Message 2 of 22
Re: 1Gig Hub4 30Mb average
See what you get past midnight.
run a ping test by BQM
jackjj
  • 12
Message 3 of 22
Hi legacy1,
Thanks for your reply.
Here's test
My Broadband Ping - Virgin
Today's speed is even worse than yesterday.
  • 20.5K
  • 828
  • 2.2K
Message 4 of 22
Guess you have lots of people in your area downloading
test here to see if 1x is the same as 6x
UK Broadband Speed Test | thinkbroadband
jackjj
  • 12
Message 5 of 22
Hi legacy1,
Look like 1x is not the same as 6x
1648064817844576255
  • 20.5K
  • 828
  • 2.2K
Message 6 of 22
Likely the way the downstream is handling the load so more connection and mean more speed.
Run CMD
netsh interface tcp show global
check Receive Window Auto-Tuning Level is normal
carl_pearce
  • 1.77K
  • 114
  • 378
Super solver
Message 7 of 22
There is clearly something wrong on the VM network.
You should post the stats from your HUB:
jackjj
  • 12
Message 8 of 22
I am actually using macOS, and I run this CMD in the VMware Fusion (installed windows 10) and shows that Window Auto-Tuning Level is normal.
jackjj
  • 12
Message 9 of 22
Hi carl_pearce,
Primary downstream channel - Locked. Is that the reason?
carl_pearce
  • 1.77K
  • 114
  • 378
Super solver
Message 10 of 22
@jackjj wrote:
Hi carl_pearce,
You are missing your DOCSIS 3.1 channel for a start (You should have one downstream)!
Could you post the other tab data, copy paste as text if you can, between multiple posts.
