Lukeastack
  • 29
Message 1 of 24
1Gig Fibre 30mbps speedtest
Just curious, should my download speeds every drop below 50 if I'm on 1gig fibre? I've reset the router a few times, not resolved the issue. I haven't had this issue before, of it at least dropping this low. although I've never actually seen my internet be above 500mbps+ on consecutive days.Screenshot_1.png
Is there a time where this would/could be acceptable?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 24
Re: 1Gig Fibre 30mbps speedtest
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Anonymous
Not applicable
Message 3 of 24
wireless or wired connection
Lukeastack
  • 29
Message 4 of 24
This is a wired connection, ranging currently from 30-50mbps on speedtest.net
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 24
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Lukeastack
  • 29
Message 6 of 24
31.5 to hub, 38.3 to computer, not sure why its being like this.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 24
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Lukeastack
  • 29
Message 8 of 24
1000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 24
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 24
Can you please
