Adam646
Message 1 of 10
1Gig- 0.01 Mb Upload. Will complaint team fix?
As the title suggests, broadband has slowed down (both WiFi and Ethernet) today down to 3Mb download, 0.01 Mb upload on the 1Gig package.
It's now actually so slow most speed tests time out before giving me results.
Restarted router multiple times, called the support, and they couldn't find a solution so passed my issue on to the complaints team.
The complaints team doesn't sound like a team that will fix my issue, more one which will try to compensate me.
I can't Work from Home anymore, can't stream videos, can barely load internet pages.
My question is: does the community know if this "Complaints Team" will try and fix my issue, or should I call again?
Tags (2)
  • 1.79K
  • 109
  • 404
Super solver
Message 2 of 10
Re: 1Gig- 0.01 Mb Upload. Will complaint team fix?
Could you run this Hub & device diagnostic speed test
Once the test starts click on : Run full test  to include the figures for uploading.
Post the results to help the analysis.
-tony-
  • 19.18K
  • 1.46K
  • 3.75K
Message 3 of 10
@Adam646 wrote:
you can call again but expect the same level of incompetence - thats how it is with VM customer service especially offshore who are clueless
the best you can hope for on the complaint is not much - they will ignore it - loose it or fob it off with some non sensible reply in bad english with even worse grammar
theres not much you can do other than a full reset and hope
after that wait for the forum team here to see if they can see anything
____________________
Tony.
Sacked VIP
jpeg1
  • 7.51K
  • 389
  • 1.46K
Legend
Message 4 of 10
The complaints team will do nothing.
Have you checked if there is a local fault?
Local check 0800 561 0061
Adam646
Message 5 of 10
I hadn't - just called now and there is no fault unfortunately.
Adam646
Message 6 of 10
Hi, I've just run it 4 times - the first two I got a message saying "Lost Connection - we have lost connection with the measurement software inside your router while running the test. Try again a bit later"
The third time I got:
Router: Download - 966 Mbps
Upload: 0.00
Latency: 14.3
Jitter: 1.41
Packet Loss: 0.13
Device: Desktop
Download: 31.0 Mbps
Upload: 0.47
Latency: 15.4
Jitter: 2.81
Packet Loss: N/A
On the fourth test (so the second successful one), I got:
Router:
Download: 182 Mbps
Upload: 0.37
Latency: 15.1
Jitter: 1.74
Packet Loss: 0.16%
Device - Desktop:
Upload: N/A
Latency: 2150
Jitter: 2132
Packet Loss: N/A
jpeg1
  • 7.51K
  • 389
  • 1.46K
Legend
Message 7 of 10
Call customer service and report it as a fault.
Adam646
Message 8 of 10
I just tried.....
They've told me to change the WIFI settings, wait 24 hours - I tried explaining that this wouldn't change anything as I have the issue via ethernet too.
They have then told me that I have to wait 1 month for OFCOM complaint to investigate....
All I want is a fix - not an OFCOM compensation....
-tony-
  • 19.18K
  • 1.46K
  • 3.75K
Message 9 of 10
@Adam646 wrote:
I just tried.....
you are again getting the stupidity of offshore who know nothing - the OFCOM comment being a case in point and just make up whatever rubbish they think will sound like a solution so they can close the call with a result [to them]
i cannot say it strong enough and loud enough - DO NOT RING OFFSHORE - wait here the agents will look and may or may not have answers
again i suggest you do a full reset
Tony.
Sacked VIP
Martin_N
  • 8.87K
  • 371
  • 536
Message 10 of 10
Hi Adam646,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue with your upload speed.
I am happy to take a look into this for you.
I will private message you now to confirm details.
^Martin
