spirit
  • 54
Message 1 of 19
1Gb upgrade but not.....
Hi all
Upgraded from M600 (Oomph package) to 1Gb (Volt package) on Tuesday and Hub 3 replaced for a Hub 5. Both used in modem mode connected to an Asus RT-AX82U.
Would always get around 650mbps at the router when using the Asus' own speed test when on the M600 package. Now getting between 800 and 900mbps but not 1k+, so happy it's gone up but can it hit 1k+ ?  Here is the info I have read is needed - thanks for any help:
spirit
  • 54
Message 2 of 19
Re: 1Gb upgrade but not.....
Router status
Refresh data
16-03-2023 07:59:59noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-03-2023 07:04:15noticeREGISTRATION COMPLETE - Waiting for Operational status
16-03-2023 07:04:11noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-03-2023 07:04:05noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-03-2023 07:04:02noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-03-2023 07:04:00warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-03-2023 07:03:58noticeHonoring MDD; IP provisioning mode = IPv4
16-03-2023 07:03:30criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-03-2023 07:03:13criticalCable Modem Reboot via RG reboot command
14-03-2023 15:20:39criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:20:21criticalCable Modem Reboot via RG reboot command
14-03-2023 15:15:45criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:15:29criticalDHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:15:28criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:15:20criticalDHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:15:19criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:15:15criticalDHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:11:33criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:09:52criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:09:47criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
14-03-2023 15:09:40criticalCable Modem Reboot due to power button reset
14-03-2023 15:09:35criticalCable Modem Reboot due to master console reset
14-03-2023 15:09:35criticalCable Modem Reboot due to SW Upgrade
Log out Language
spirit
  • 54
Message 3 of 19
Router status
Refresh data
14110000006.339QAM 2561
24190000006.439QAM 2562
34270000006.639QAM 2563
44350000006.839QAM 2564
54430000006.739QAM 2565
64510000006.939QAM 2566
74590000006.739QAM 2567
84670000006.739QAM 2568
94750000006.839QAM 2569
104830000006.739QAM 25610
114910000006.539QAM 25611
124990000006.339QAM 25612
135070000006.339QAM 25613
145150000006.439QAM 25614
155230000006.739QAM 25615
165310000006.939QAM 25616
175390000007.139QAM 25617
185470000007.139QAM 25618
195550000007.239QAM 25619
205630000007.339QAM 25620
215710000007.639QAM 25621
225790000007.839QAM 25622
235870000007.939QAM 25623
24595000000839QAM 25624
25603000000839QAM 25625
266110000008.239QAM 25626
276190000008.239QAM 25627
286270000008.439QAM 25628
296350000008.540QAM 25629
306430000008.740QAM 25630
316510000008.840QAM 25631
1Locked3900
2Locked3930
3Locked3930
4Locked3950
5Locked3940
6Locked3920
7Locked39100
8Locked39160
9Locked39140
10Locked39120
11Locked39160
12Locked39200
13Locked3970
14Locked39210
15Locked39130
16Locked39130
17Locked3970
18Locked3980
19Locked39110
20Locked39110
21Locked39140
22Locked39120
23Locked39100
24Locked39120
25Locked39120
26Locked3960
27Locked39230
28Locked39150
29Locked40130
30Locked4090
31Locked4060
Log out Language
spirit
  • 54
Message 4 of 19
Router status
Refresh data
04960000041.55120QAM 161
14310000041.35120QAM 162
236600000415120QAM 163
33010000041.85120QAM 164
42360000041.85120QAM 165
0ATDMA0000
3ATDMA0000
4ATDMA0000
Log out Language
spirit
  • 54
Message 5 of 19
Router status
Refresh data
General Configuration
Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig file
Allowed
3
Enabled
3.1
cmreg-vmdg660-bbt076+voc-b.cm
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateSFIDMax Traffic RateMax Traffic BurstMin Traffic Rate
70886
1230000450 bps
42600bytes
0 bps
70888
128000 bps
3044bytes
0 bps
Primary Upstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling TypeSFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type
70885
55000270 bps
42600bytes
0 bps
42600bytes
Best Effort
70887
128000 bps
3044bytes
0 bps
1522bytes
Best Effort
Log out Language
spirit
  • 54
Message 6 of 19
  • 1.93K
  • 125
  • 446
Super solver
Message 7 of 19
Seeing 900Mb/s is fine.
Allowing for transmission overheads, 940Mb/s is about the limit of devices with 1 Gb/s network ports.
spirit
  • 54
Message 8 of 19
But isn't the Hub 5 2.5Gb/s and the Asus is 2.4Gb/s and using a Cat 8 cable....so surely should at least expect 1k+ speeds ?
RavenLunatic
  • 10
Message 9 of 19
Asus 2.4Gb/s is probably 2.4Ghz WiFi.  Its not the same thing as 2.5Gb Ethernet.
  • 1.93K
  • 125
  • 446
Super solver
Message 10 of 19
I based my feedback on the info for Asus RT-AX82U from the link below :-
https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax82u/techspec/
Where network ports are listed as :
++ RJ45 for Gigabits BaseT for WAN x 1
++ RJ45 for Gigabits BaseT for LAN x 4
To exceed about 940Mb/s, requires 2.5Gb/s at the WAN and LAN sides of the Router and on the Computer.
Using the Gig 1 service for a work task might be more interesting than being anti antisocial and running frequent speed tests.
