  • 5
Message 1 of 11
1Gb - not getting headline speed
I installed my new 1Gb service over the weekend. I've tried running numerous speed tests when connected via Ethernet from a laptop to the Hub 3. The highest speed I've obtained is ~500Mb (once). Sometimes it's as low as 150Mb and often in the 350Mb range. I've used speedtest.net and tried in both IE and Firefox browsers. I also downloaded the Ookla Windows app with the same results. Upstream is consistently about 50Mb/s.
Downstream, Upstream and Network log as requested (latter two will be in replies to this post to get around forum post character limits):
14110000002.00000038.605377QAM2561
0   UNSUPPORTED0
24190000001.70000137.636276QAM2562
34270000002.09999838.605377QAM2563
44350000001.90000237.636276QAM2564
54430000002.09999837.636276QAM2565
64510000002.20000137.636276QAM2566
74590000001.00000037.355988QAM2567
84670000001.00000037.636276QAM2568
94750000001.20000137.636276QAM2569
104830000001.29999937.636276QAM25610
114910000001.70000137.636276QAM25611
124990000001.79999937.355988QAM25612
135070000002.00000038.605377QAM25613
145150000002.40000238.605377QAM25614
155230000002.40000237.636276QAM25615
165310000002.20000137.636276QAM25616
175390000002.29999937.636276QAM25617
185470000002.09999837.355988QAM25618
195550000001.90000237.636276QAM25619
205630000002.09999837.636276QAM25620
215710000001.90000237.355988QAM25621
225790000001.70000137.636276QAM25622
235870000001.90000237.636276QAM25623
245950000001.90000237.355988QAM25624
256030000001.40000237.636276QAM25625
266110000001.50000037.355988QAM25626
276190000001.20000137.355988QAM25627
286270000000.70000136.609653QAM25628
296350000000.90000237.355988QAM25629
306430000000.70000136.609653QAM25630
316510000000.29999937.355988QAM25631
1Locked0230
0NotLocked000
2Locked1745402996230
3Locked1722080744420
4Locked1751168442420
5Locked1740617755350
6Locked1746505181620
7Locked1595535774600
8Locked1739526776610
9Locked1732339924570
10Locked1731203698610
11Locked1738894755430
12Locked17216133761070
13Locked1715999761760
14Locked1714925551860
15Locked1730352574850
16Locked17066285731110
17Locked1689461428950
18Locked16976326921510
19Locked16976641821480
20Locked16995725831530
21Locked16913223581700
22Locked16892220741710
23Locked17126735911510
24Locked18326845431850
25Locked18144617091920
26Locked18196436581830
27Locked18489393491760
28Locked18563641542170
29Locked18522614302340
30Locked19177265682260
31Locked10174291042270
  • 11.39K
  • 790
  • 1.61K
Message 2 of 11
Re: 1Gb - not getting headline speed
Is the device your using to test capable of the headline speed?
I work for Virgin Media and my posts are my own opinions
  • 4.83K
  • 883
  • 1.28K
Message 3 of 11
Hello
You say a hub 3 surly you mean a hub 4 what does the internal speedtest come back at ?
Regards Mike
  • 5
Message 4 of 11
And the rest of the requested information
15370000048.5205995120 KSym/sec64QAM2
23940000048.0205995120 KSym/sec64QAM4
34620000048.5205995120 KSym/sec64QAM3
46030000049.0205995120 KSym/sec64QAM1
1US_TYPE_STDMA0030
2US_TYPE_STDMA0030
3US_TYPE_STDMA0030
4US_TYPE_STDMA0030
Thu Jan 1 00:01:16 19704Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:01:49 19703No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 13:59:59 20195MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 14:00:03 20195RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 14:00:03 20195RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 14:00:12 20196SW Download INIT - Via Config file kfoA,.iyewrkldJKDHSUBsgvca698
Sun Dec 8 14:01:30 20196SW download Successful - Via Config file
Sun Dec 8 14:03:55 20195MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 14:04:02 20195RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 14:04:04 20193No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 14:04:22 20193Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 14:04:22 20193Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 14:04:22 20195TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 14:04:23 20195RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 15:43:49 20194DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 16:11:12 20194DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 16:11:12 20196DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Dec 8 18:15:40 20195MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Dec 9 04:55:36 20195RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Dec 9 08:25:19 20195MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Dec 9 08:25:24 20195RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Dec 9 21:21:32 20193No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • 5
Message 5 of 11
Dell Latitude 7480 with 10/100/1000 Mb/s Ethernet port
I'd expect with some system overhead I may get slightly under 1Gb/s, but not consistent average of 300Mb/s
  • 5
Message 6 of 11
Yep sorry my bad I meant Hub 4
I don't know what you mean by "internal speed test"?
  • 4.83K
  • 883
  • 1.28K
Message 7 of 11
Hello
The hub 4 has it own samknows speedtest built into the hub.
Regards Mike
  • 4.83K
  • 883
  • 1.28K
Message 8 of 11
Hello
Here is how to access it https://samknows.com/blog/virgin-media-launches-samknows-realspeed
Mike
  • 5
Message 9 of 11
That's really helpful thanks!
I've just run it and it shows my download speed as 1065Mb/s and 52.2Mb/s upstream
My laptop must be really [removed] 🙂
[MOD EDIT: Inappropriate language removed, please review the Forum Guidelines]
  • 4.83K
  • 883
  • 1.28K
Message 10 of 11
Hello
Lets see if we can get your laptop faster download and run https://www.speedguide.net/files/TCPOptimizer.exe
When it runs choose Optimal down at the bottom right and then Apply Changes you will need to restart the PC to get it applied.
As a side line, the maximum you will get out of Ethernet is Approx 940mpbs.
Regards Mike
