on 13-09-2022 12:26
Hi there,
As its near impossible to get through to Virgin on the phone I was wondering if there is anyone who knows what the actual average speed should be for the 1Gb download and tell a way to check everything to do with the connection or even arrange a visit from an engineer to check the old cabling I have. I have read I should get something between 1094 - 1140 Mbps with a measlely guaranteed speed of 565 Mbps which is shocking with the price you pay.
Any help would be most appreciated
on 13-09-2022 13:07
First thing to try is https://samknows.com/realspeed/
Actual download speed really varies depending on the speed of the server you are downloading from but this will tell you speed at router.
You could try using a download manager such as IDM and then try downloading a large file from a game site or something like that.
Another option is download a torrent which is got many seeds for example Ubuntu server torrent this should max out your connection.
You could also use the normal speed tests available but these don't always prove to be accurate.
I can max out my connection on non encrtpted connection at around 65MB/s or around 45MB/s with SSL
on 13-09-2022 15:05
on 14-09-2022 09:14
on 14-09-2022 09:20
So this sounds absolutely correct for 1gb. What's the actual issue, are you expecting faster when downloading?
Download a test torrent or something from a fast reliable server using a download manager such as IDM.
Either way sounds like the connecting from hub to pc is fine.
on 14-09-2022 11:54
14-09-2022 16:33 - edited 14-09-2022 16:35
That's limitations of 1gb ethernet adapters in order to achieve the maximum speed you will need router and nic with 2.5gbe
on 14-09-2022 19:11
@bemybezzyman wrote:
Sorry I was just expecting for the speed would be the same from the outside box through to the PC. Just didn't expect to lose nearly 200mb download speed between the two thats all
Does your PC have a 2.5GbE or higher ethernet adapter?
Even then the HUB 4 only has 1Gbps ethernet ports.
You'd need the HUB 5 that has one 2.5Gbps port to get full speed to one device.
Gig1 is designed to be shared across multiple devices at the same time.
on 16-09-2022 19:48
Hi there @bemybezzyman
Thank you so much for your post and welcome back to the forums, also a big thank you to our community members who have assisted on this so far.
It does sound as though you are getting the expected speeds for your package.
Have you been able to try the steps recommended by @carl_pearce at all?
Thank you.
on 16-09-2022 20:37
@Ashleigh_C wrote:Hi there @bemybezzyman
Snip…
Ashleigh,
Carl didn’t actually recommend any steps at all for the OP to follow. Rather he was just pointing out the reality of the situation, ie on a Hub 4 you will never, ever get more than about 940 Mb/s download speed over Ethernet.
Tell me, did you actually read the thread and understand what was being discussed, before crashing in with a standard scripted response? Be honest, you didn’t did you?😳
