1GIG BB not working - 466MBPS Max
FLINTL84
Hi All,
I'm really not that well up on speed of BB but thought I'd treat myself to a better connection speed for my gaming & streaming. I upgraded from 350bb to 1Gig - However this has mad very little difference at all, the max download speed I'm getting is 466mbps. I'm so frustrated as I've called Virgin Media CC & just get passed round from department to department with no resolution. I'm using a hub 4, I've also just fount out that this hub in not Wi-Fi 6 compatible  which makes a huge diffrence with my PS5 gaming experience. Is their a work around or should I just cancel as I'm in my 14 day cooling off period? Many Thanks for any advice anyone can provide.
1 REPLY 1
Legend
466Mb/s via Wi-Fi is very decent, are you sure there is a problem here ?
What does this show :
Share a screen shot of the results.
