stepheno1989
  • 33
Message 1 of 18
1GB speed is never stable and consistent.
Having many dropouts and slow download speed on 1GB line.
Downstream:
Logs:
  • 1.87K
  • 116
  • 432
Super solver
Message 2 of 18
Re: 1GB speed is never stable and consistent.
The Hub's signal stats looked decent.
Try this Hub test :-
Once the test starts click on Run full test to show all the figures.
Share the results to help the analysis.
stepheno1989
  • 33
Message 3 of 18
Constant disconnects last night, can someone check the logs. Most certainly happed between 9-10PM.
I am unable to run https://www.samknows.com/realspeed/ Probably due to me being in Modem mode
  • 6.8K
  • 591
  • 1.78K
Message 4 of 18
Logs look to be showing problems with the Upstream.
Setup a BQM and post the shared live link for comment.   www.thinkbroadband.com/ping
stepheno1989
  • 33
Message 5 of 18
Why do my images for logs keep disappearing?
I will do that
  • 6.8K
  • 591
  • 1.78K
Message 6 of 18
Images will not be shown if they have identifying information showing, i.e. MAC addresses etc.
You should copy and paste the information as text into several posts.  The Board software will remove any personal information for you.
stepheno1989
  • 33
Message 7 of 18
Thu 02/03/2023
09:52:02
6CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
08:13:03
6US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
08:10:32
3No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/03/2023
04:11:03
6US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:48:17
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:47:54
6US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:47:54
5DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:47:38
Wed 01/03/2023
21:47:38
5MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:44:07
Wed 01/03/2023
21:42:09
5Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:42:09
6CM-STATUS message sent. Event Type Code: 2; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:41:47
3SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:38:09
6CM-STATUS message sent. Event Type Code: 5; Chan ID: 9; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:37:59
Wed 01/03/2023
21:37:11
Wed 01/03/2023
21:36:57
Wed 01/03/2023
21:35:36
Wed 01/03/2023
21:35:05
Wed 01/03/2023
21:30:02
Wed 01/03/2023
21:29:33
Wed 01/03/2023
21:26:13
Wed 01/03/2023
21:25:52
Wed 01/03/2023
21:24:20
Wed 01/03/2023
21:24:20
Wed 01/03/2023
21:20:37
Wed 01/03/2023
21:20:26
Wed 01/03/2023
21:16:07
Wed 01/03/2023
21:15:49
Wed 01/03/2023
21:14:32
Wed 01/03/2023
21:14:06
Wed 01/03/2023
21:13:35
Wed 01/03/2023
21:13:17
Wed 01/03/2023
21:10:23
6CM-STATUS message sent. Event Type Code: 4; Chan ID: 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 01/03/2023
21:10:05
Wed 01/03/2023
21:09:59
Wed 01/03/2023
21:04:53
Wed 01/03/2023
21:04:41
Wed 01/03/2023
20:44:36
Wed 01/03/2023
20:44:20
Wed 01/03/2023
20:39:00
Wed 01/03/2023
20:38:18
Wed 01/03/2023
20:27:28
Wed 01/03/2023
20:27:03
Wed 01/03/2023
20:26:54
Wed 01/03/2023
20:26:41
Wed 01/03/2023
20:11:39
Wed 01/03/2023
20:11:26
Wed 01/03/2023
20:10:20
Wed 01/03/2023
20:10:19
stepheno1989
  • 33
Message 8 of 18
stepheno1989
  • 33
Message 9 of 18
Can anyone suggest anything on this matter? Paying a lot of money every month for a completely substandard service. Very annoying.
stepheno1989
  • 33
Message 10 of 18
Bump
Can't speak to anyone on the phone, impossible. How is it even possible to provide so little support for your product?
As you can see from the Live Graph I linked, I have constant disconnects, packet loss, latency, and sporadic speeds.
ri 03/03/2023
09:56:38
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
09:56:35
Fri 03/03/2023
09:56:35
Fri 03/03/2023
09:56:17
Fri 03/03/2023
09:53:52
Fri 03/03/2023
09:52:21
Fri 03/03/2023
09:52:19
Fri 03/03/2023
09:52:15
Fri 03/03/2023
09:52:06
6CM-STATUS message sent. Event Type Code: 5; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
09:51:26
Fri 03/03/2023
09:51:25
Fri 03/03/2023
09:51:12
Fri 03/03/2023
09:50:51
Fri 03/03/2023
09:50:42
Fri 03/03/2023
09:48:37
Fri 03/03/2023
09:48:13
Fri 03/03/2023
09:46:56
Fri 03/03/2023
09:46:44
Fri 03/03/2023
09:46:29
Fri 03/03/2023
09:46:28
Fri 03/03/2023
09:44:46
6CM-STATUS message sent. Event Type Code: 5; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
09:44:21
Fri 03/03/2023
09:39:09
Fri 03/03/2023
09:39:04
Fri 03/03/2023
09:38:39
Fri 03/03/2023
09:38:28
Fri 03/03/2023
09:35:34
Fri 03/03/2023
09:35:05
Fri 03/03/2023
09:34:59
Fri 03/03/2023
09:34:35
Fri 03/03/2023
09:34:09
Fri 03/03/2023
09:34:08
Fri 03/03/2023
09:33:59
Fri 03/03/2023
09:33:57
Fri 03/03/2023
09:33:33
Fri 03/03/2023
09:33:21
Fri 03/03/2023
09:32:54
Fri 03/03/2023
09:30:49
Fri 03/03/2023
09:30:00
Fri 03/03/2023
09:29:52
Fri 03/03/2023
09:29:10
Fri 03/03/2023
09:28:41
Fri 03/03/2023
09:28:31
Fri 03/03/2023
09:28:18
Fri 03/03/2023
09:28:08
Fri 03/03/2023
09:27:50
Fri 03/03/2023
09:27:49
Fri 03/03/2023
09:27:47
Fri 03/03/2023
09:27:46
6CM-STATUS message sent. Event Type Code: 2; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/03/2023
09:27:45
